Posted: Mon May 02, 2011 9:00 am |
Lee wrote: |
What? save peugeot 20p?  |
It is peugeot remember
Have fun though, and dont forget you porbs need to drain brake fluid soon
| Team Impossible Possible
Posted: Mon May 02, 2011 9:04 am |
Addaz wrote: |
Lee wrote: |
Have fun though, and dont forget you porbs need to drain brake fluid soon  |
Done it
The drivers bleed screw was a b***h tho
Posted: Mon May 02, 2011 3:13 pm |
same rad as mine... you dont even need to undo the bleed screw. just fill up the coolant bottle and let it warm up with the cap off the bottle and top up as needed.
| if it dont scuff the ruff it aint low enuf | |
Posted: Mon May 02, 2011 4:51 pm |
If you're changing the coolant, course you need to open the bleed screws to let the air out of it.
Think of you radiators at home, you bleed them...dont you
Posted: Mon May 02, 2011 4:58 pm |
i did change the coolant . the system bleed its self . once the thermostate had opened. and with the cap off the coolant bottle air is able to escape. havent had any problems yet
Posted: Mon May 02, 2011 5:01 pm |
dumdum0910 wrote: |
i did change the coolant . the system bleed its self . once the thermostate had opened. and with the cap off the coolant bottle air is able to escape. havent had any problems yet |
it might takes a while but it do work
Posted: Wed May 04, 2011 5:38 am |
hi. I am hoping to do this on my 206 SW 2 litre TD this weekend. So would i just remove the bottom pipe, let all the water run out. Then fill it back up, leave the cap off the water tank, then start the car and let it get hot and it would bleed itself?
Thank you
Posted: Wed May 04, 2011 11:05 am |
If you could rely on the system self bleeding do you think they would have still fitted bleed screws?
You can bleed most of the system without even switching the engine on.
Posted: Wed May 04, 2011 12:09 pm |
The system has to be bled as the heater pipes and matrix are a bit higher or the same level than the resevoir, bubbles dont go downhill !!! basic physics.
| An Ex '03 1.4 GLX driver, German technology all the way now. | |
