Posted: Mon May 02, 2011 5:56 am |
15" GTi Foudre alloys
just got some of these but came without the bolts.
... the bolts on my old alloys look too short.
.... can anyone link me to the ones i need please ?
Posted: Mon May 02, 2011 5:57 am |
They are hubcaps you have in your sig?
You need peugeot alloy ones, they are cheap new
| Team Impossible Possible
Posted: Mon May 02, 2011 5:59 am |
Addaz wrote: |
You need peugeot alloy ones, they are cheap new |
yeah , thats an old pic
my old alloys was peugeot ones, but the bolt is still too short.
also forgot to ask, the ones off my old alloys are tapered, will i need flat or tapered for these, tried searching but couldnt find any info.
do halfords stock the ones i need ?
Posted: Mon May 02, 2011 6:09 am |
Flat mate, and i dont think so?
Tapered are for steelies i think
Posted: Mon May 02, 2011 6:16 am |
Ive just broughlt some sirocco alloys and phoned peugeot about bolts they quoted me £2.26 each for bolts with part number 540567
I then asked for a price on a bolt part number i got of servicebox 540565 they quoted me £1.70 each.
When i asked the difference between the two the only difference is the size of the head of the bolt. There both flat seated bolts with a shoulder. 540567 being 17mm and 540565 being 19mm so im going to go with the later and save about £10 in the process.
Posted: Mon May 02, 2011 6:17 am |
thanks .
just to confirm :
these are the old ones:
new ones ( well, secondhand lol )
... so only peugeot for the bolts ?
Posted: Mon May 02, 2011 6:31 am |
They can also be found Here
Posted: Mon May 02, 2011 7:04 am |
Posted: Mon May 02, 2011 7:26 am |
thanks all.
will take a run over tomorrow , i hate bank hols
Posted: Mon May 02, 2011 8:17 am |
perry081064 wrote: |
thanks all.
will take a run over tomorrow , i hate bank hols  |
You original alloy wheel bolts had a 17mm head.
The bolts for the Foudre wheels have a 19mm head.
Make sure the wheel brace is suitable
Posted: Mon May 02, 2011 9:57 am |
MrBSI wrote: |
thanks all.
Make sure the wheel brace is suitable  |
i have one of those braces with 4 different sized heads, hopefully one of those will be the right one.
..... then again, knowing my luck
mr.bsi is this the right part number for the ones you got ( 540565 ) ?
Posted: Mon May 02, 2011 10:23 am |
mr.bsi is this the right part number for the ones you got ( 540565 ) ? |
Nope, you need Peugeot / Citroen part number 5405 67 Mounting screw £2.26 each
Posted: Mon May 02, 2011 10:49 am |
MrBSI wrote: |
Nope, you need Peugeot / Citroen part number 5405 67 Mounting screw £2.26 each |
cheers mr.bsi
20 miles to my nearest dealer so just making sure i get the right ones
i take it becouse they have a flat head, its gives you those few extra mm for a better fitting to the hub.
i ask this becouse i noticed the actual hub thread is slightly ingressed into the hub
Posted: Mon May 02, 2011 11:09 am |
i ask this becouse i noticed the actual hub thread is slightly ingressed into the hub |
No idea, thats just the part number for the alloy wheel Peugeot say to use with the Foudre alloy wheel.
You can get them from a Citroen main dealer if there nearer
Posted: Tue May 03, 2011 8:08 am |
