Latest: tbafonso
Overall: 17130
Online Now [543]:
Visitors: 542
Today: 40421
Total: 102777397
Forums › The Car › 206 Talk › Crankshaft Pulley 2.0 Hdi
Go to page Previous  1, 2
Gaz-M
PostPosted: Thu Nov 24, 2011 4:23 pm Up
I had a noise from mine when i bought it, had recently had a new pulley. Turned out to just be the tensioner. Its adjustable in 2 ways- 1 part manually and other automatically. The manual part needed adjusted so it was holding the belt at the furthest most point, then refitted the belt and all is spot on! Was only noisy at tick-over with mine..
Diesel Power!!
mjsroofing
PostPosted: Sun Nov 27, 2011 4:43 am Up
I recently changed the bottom pulley on my 1.4 hdi, cost £45 and took 20 mins to change.
How do you adjust the belt tensioner manually then, i've never heard of this.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
Gaz-M
PostPosted: Sun Nov 27, 2011 1:51 pm Up
The actual tensioner wheel is offset so can be moved around ajusting the tension.
Diesel Power!!
Page 2 of 2
