Posted: Tue May 03, 2011 2:52 pm |
Car not had it done in a while and thinking of full service?
Does anyone know how much its likely to cost?
Posted: Tue May 03, 2011 2:53 pm |
what car?
Posted: Tue May 03, 2011 2:54 pm |
sorry 206 1.4lx
Depends if you're doing it yourself?
Did mine today:
Oil Total Quartz 7000 £28
Oil Filter
Air Filter
Sump Plug Washer £20 ( should of been more, dealer had no change )
An hour in time.
Maybe throw in a fuel filter on top, don't know how much they are for yours mind.
Posted: Tue May 03, 2011 2:56 pm |
how much from a garage?
Posted: Tue May 03, 2011 2:57 pm |
between 50 to 200.
Posted: Tue May 03, 2011 3:13 pm |
i got quotes from 140 to 180 for my wee 1.1, ended up doing it my self after i had to change my oil sump my self, really is quite easy and your saving a good load too mate
Posted: Tue May 03, 2011 3:21 pm |
Don't forget the pollen filter.
Posted: Tue May 03, 2011 3:26 pm |
£180 from pug for a 40k service... only really covers the basics though.
I've spent around £100 doing my car myself, but have upgraded a few bits from standard ie air filter, oil, spark plugs.
Posted: Tue May 03, 2011 5:28 pm |
I did mine myself
But might be an idea to ask the garage/dealer u got urs from. If u didnt buy private. I called the garagae i got mine from. And they offered 145 for full service. With courtesy car. Only reason i didnt was because it was 10 miles from my work and my work is 23 miles from home. And i do 12 hour shifts
| Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14) | |
Posted: Tue May 03, 2011 5:40 pm |
Squeaker wrote: |
Did mine today:
Oil Filter
Air Filter
An hour in time.
Maybe throw in a fuel filter on top, don't know how much they are for yours mind. |
for a copper washer?
dear god!
Posted: Wed May 04, 2011 3:08 am |
ExoVyper wrote: |
Squeaker wrote: |
Did mine today:
Oil Filter
Air Filter
An hour in time.
dear god! |
And its not even copper now..........
Posted: Wed May 04, 2011 3:16 am |
people forget that when your car is serviced a lot of other stuff is checked over too.
its all very well doing it yourself ( ive done my own services for years) but you still need to get it checked over every now and then by someone that knows what they are doing unless you know a lot about telltale signs of wear in components etc.
Posted: Wed May 04, 2011 5:36 am |
Kersh wrote: |
its all very well doing it yourself ( ive done my own services for years) but you still need to get it checked over every now and then by someone that knows what they are doing unless you know a lot about telltale signs of wear in components etc. |
Isn't that what an MOT is for though?
Posted: Wed May 04, 2011 3:34 pm |
just be wary if you have breakdown cover. ive got AA and they have in there small print that my car has to be serviced by a garage, pain in the a**e. but knowing my luck ill cancel it and then break down.
| 2001, 206 1.4 lx first car | |
