Latest: Beduff1977
Overall: 17134
Online Now [587]:
Visitors: 586
Today: 273388
Total: 107933336
Forums › The Car › 206 Talk › DIY or not. bottom engine mount 2.0hdi
spud_owen
PostPosted: Mon Jan 10, 2011 2:25 am Up
Anybody changed there bottom engine mount and is it a DIY job? Car is a 2.0hdi, i was looking to just change the whole bracket over rather than replace to bush.
Im not bad at mechanicing but bear in mid i only ahve a trolley jack and axle stands, is this something i could do? any advice appreaciated.
Honda Accord cdti....205GTI
LACEY AND OWEN ARCHITECTURAL SERVICES
www.laceyandowen.co.uk
cartoonhead
PostPosted: Mon Jan 10, 2011 2:53 am Up
should be able too as it 2 bolts Smile
spud_owen
PostPosted: Mon Jan 10, 2011 4:40 am Up
have you done it? i read somewhere that the shaft has to be removed as well, if its acase of unding the bolts and sloting in should be a easy!
kieron
PostPosted: Mon Jan 10, 2011 4:45 am Up
the mount is pressed into the bracket unless you have got a whole lot or have a 2nd hand one
they is 2 11mm bolts they have to slide out and i think 4 or 5 13mm bolt they go,s into the block, its quite easy on a ramp never done it on the ground tho
drive shaft has to be removed and you will lose the gearbox oil so make sure you have some to hand
Account suspended
spud_owen
PostPosted: Mon Jan 10, 2011 6:55 am Up
cheers man, just what i wanted.
Going to get complete second hand one with bracket, and just swap them over. bit of a shitter aboutt he drive shaft, where abouts is the refill tube from the gear box?
I going to have to jack her up and see how much room i have got to play with i think!
Kersh
PostPosted: Mon Jan 10, 2011 7:03 am Up
i did it on axle stands on my driveway.. its easy enough
Member number: 36
cartoonhead
PostPosted: Mon Jan 10, 2011 9:43 am Up
soz bud i forgot the bush is on the bracket and not the bar Sad
just looked tru me 206 bits and if you have no luck at the scrappers getting one ive one in good condition that i was gonna keep as a in-case spare Smile
i was at the hospital seeing my baby boy when i did first reply or i would have checked the bar i thought it was on.
spud_owen
PostPosted: Mon Jan 10, 2011 12:43 pm Up
ah not a problem man, understandable with a new baby! i reckon i can do it just need the weather to improve now!
How much do you want for your mount? there's one on ebay at the mintue for 22 quid including postage, could you do it for that?
gti180boy
PostPosted: Mon Jan 10, 2011 2:43 pm Up
This is pretty much right, drive shaft does have to be removed.
When i did my kierons for him to remove the old bush out of the bracket can be a right a**e of i job.
So as a diy job might be abit hard to get the old bush out by your self.
kyle
180 Doctor
cartoonhead
PostPosted: Mon Jan 10, 2011 3:46 pm Up
no probs Smile
spud_owen
PostPosted: Mon Jan 31, 2011 8:29 am Up
finally got around to doing this, turned out that it wasnt the bottom mount but the top mount! even though i had replaced this 3 months ago, things are abit better but he car is still handling a little funny
stevedude
PostPosted: Mon Jan 31, 2011 9:21 am Up
how do you tell if mount needs changing? without being told by garage lol
Happydays
spud_owen
PostPosted: Tue Feb 01, 2011 2:56 am Up
you could feel mine moving about when you accellerated / changed gear also was affecting steering and was bloody scary at times!
stevedude
PostPosted: Sun May 15, 2011 7:45 am Up
lol i know one is gone, but im bolloxed if i know which it is lol
Happydays
