Latest: tbafonso
Overall: 17130
Online Now [547]:
Visitors: 546
Today: 32275
Total: 102876118
Forums › The Car › 206 Problems › Radio keeps resetting
karimali831
PostPosted: Sat May 14, 2011 8:27 am Up
When I set it to my settings and turn off the engine for a while, my radio settings reset... but when I turn it off then turn it back on straight away, the radio settings are set to how I set it.
why does it reset when the engine is off for a while? how can I fix this also?
another question is, my clock is working (not radio clock), the clock built, visibility is very poor. I can barely see it... dark orange colou??
206 GTI 180
cartoonhead
PostPosted: Sat May 14, 2011 8:30 am Up
standard or aftermarket head unit ?
if its after market you need to swap your constant live and your ignition live over
DanPug206
PostPosted: Sat May 14, 2011 8:38 am Up
Your bulb has gone in your clock mine went not long ago
Bulb cost 25p from local auto spares
Take the top bit of the centre consol of undo the screws and the bulb twists and pulls out the back of the clock unit Smile
Saphire Blue 206 (Gti Replica) SOLD
08 Seat Ibiza Sport
seanbmx
PostPosted: Sat May 14, 2011 8:48 am Up
What He Said
buy it, fix it, mod it
karimali831
PostPosted: Sat May 14, 2011 8:49 am Up
it is a JVC KD-R301. If that is what you mean.. do you think they will sell bulb at halfords?
Thanks guys!
206 GTI 180
Norvvv
PostPosted: Sat May 14, 2011 9:10 am Up
Swap the red and yellow wires on the back of the HU.
2001 1.4lx
PrePlexed 5 door.
Lewis
PostPosted: Sat May 14, 2011 9:48 am Up
red and yellow wires need swapping... sortedddd
need new bulbs for your MFD, cant remember which bulb type but someone will be able to tell you... You can then just put off the centre console and get to them that way!
Tivoli LX 1.1
Black GTI 180
White VXR Burg
dumdum0910
PostPosted: Sat May 14, 2011 9:58 am Up
if you car is pre-plexed - everything shuts off after 3 mins you will have to splic in to a constant live. you can get this from the hazard switch or clock display .
karimali831
PostPosted: Sat May 14, 2011 10:12 am Up
wow it seems quite complicated to switch the red and yellow wires.... hmm? It must be something else...
also to get the clock unit out do I need alan key?! because I'm sure I got correct size but not going in.. ahh.
206 GTI 180
cartoonhead
PostPosted: Sat May 14, 2011 10:19 am Up
there torx screws
Norvvv
PostPosted: Sat May 14, 2011 10:21 am Up
Are you serious? How in anyway is that complicated.
PostPosted: Sat May 14, 2011 10:26 am Up
The screws are torx 20, use the correct size torx bit, using an allen key on torx fixings ruins the screwhead.
As for the red & yellow wire swop, its been covered many times on the forum, its not rocket sicence Wink
karimali831
PostPosted: Sat May 14, 2011 10:39 am Up
it is rocket science, it feels like the only way to swap it is to pull out both wires... causing damage. I'm confused what you mean:
look:
imageshack.us/m/62/163...011463.jpg
206 GTI 180
PostPosted: Sat May 14, 2011 10:41 am Up
Those bullet connections are put in the loom for a reason Wink
Seb
PostPosted: Sat May 14, 2011 10:55 am Up
Staff - Seb
Those fecking massive rubber coated bullet connectors with the red and yellow wire.
Swap them around.
Or were you genuinely going to pull them out of the crimps Razz
