Posted: Fri May 20, 2011 9:27 am |
Just got back from the garage, and the car flew through it's MOT. No advisories. It was described as a good example.
Filled up with Shell v-power before setting off on the 38 mile journey to the garage. CO2 0.09% (0.20), HC 18ppm (200), Lambada 1.003 (0.970 - 1.030) (limits in brackets)
Just shows that regular maintainance and weekly checks keep the car in top condition.
Posted: Fri May 20, 2011 9:34 am |
My turn soon.
Posted: Fri May 20, 2011 10:31 am |
macca1411 wrote: |
Just shows that regular maintainance and weekly checks keep the car in top condition. |
gratz, = NO BILL!!!
Posted: Fri May 20, 2011 10:35 am |
With small engines like ours it just shows money is better spent on servicing than mods I had my MOT in September and had similarly good results to you
It last had a service over 12 months ago so I'm going to get that done soon and get a couple of niggles sorted (I think the crankshaft pulley needs doing due to horrible squeek, and thrust bearing as I can hear a clank when I put the throttle on in a low gear, or even bring the clutch up slowly when stationary with the window open)
Posted: Fri May 20, 2011 3:23 pm |
iainlovatt wrote: |
gratz, = NO BILL!!! |
Yeah a bill was involved. Mechanic is called Bill
Posted: Fri May 20, 2011 4:31 pm |
My Pug was looked after and always got advisories. My current car iv put through 3 Mot's and straight through everytime!!
| 4.0 V8 S-Type Jaguar
Image removed due to size | |
