Online Now [126]:
Visitors: 125
Today: 7454
Total: 105984606
Forums › The Car › 206 Problems › arch liner
arch liner
kev85
PostPosted: Tue May 24, 2011 7:47 am Up
soory if this is a stupid question but need to know how hard it is to remove the arch liner.
Need to get my side repeater bulb changed for mot and have not been able to undo the connecter with a screwdriver following the how to guide.
Been told that if i remove the arch liner i will be able to reach up and undo it..is that true.
Cheers for any help.
206 gti sp
PostPosted: Tue May 24, 2011 7:54 am Up
no its not hard to remove the arch liner, if you take the wheel off u will see the few mushroom clips (and a few torx ) holding it in place.
kev85
PostPosted: Tue May 24, 2011 7:57 am Up
cheers. will give it a go if i cant follow the how to..would this be the next best way to get at the side repeater.
206 gti sp
furryhobnob
PostPosted: Tue May 24, 2011 8:01 am Up
If you open the door you can reach in through the gap and push the clip to get it out, very easy
kev85
PostPosted: Tue May 24, 2011 8:03 am Up
cheers furry. been trying to do it with a screw driver as per the how to as cant reach it with my hands. will give it another go but at least im on the right lines. cheers for the response
206 gti sp
furryhobnob
PostPosted: Tue May 24, 2011 8:06 am Up
I'm not a skinny guy, it is quite tight but you can just reach in and just unclip it, took me about 1 min each side
PostPosted: Tue May 24, 2011 8:37 am Up
I've just done mine. Turned wheel onto full lock, undid the 2 torx screws at the bottom of the liner, eased the liner away from the wing and got to the repeater.
Was surprised how filthy it was behind the liner though. Think wheels will be off and liners fully out so that I can give it a proper clean behind.
kev85
PostPosted: Tue May 24, 2011 9:13 am Up
cheers for the replies people. managed to squeeze my hand in and do it that way..replaced the bulb and what do you know..still doesnt work.
to change the thread slightly what can the problem be now. All the other hazard lights work when its switched on so unless they all have different fuses guessing it's nothing to do with the fuse. Other than a lose connecter, which it doesn't appear to be, i dont have a clue...answers on a postcard please as need to sort it for it's mot.
cheers.
206 gti sp
