Posted: Thu Apr 28, 2011 12:46 am |
i have crystal headlights, what bulbs do i need, im wanting to order some white light bulbs. are they both h7 ? + what size do i need for the side lights ? can they be swapped to L.E.D. thanks
**this is a post for a friend not the owner of this account **
Posted: Thu Apr 28, 2011 12:48 am |
Trade Rating: +36
Posted: Thu Apr 28, 2011 12:59 am |
Both H7 headlight bulbs , sidelights 501 get LED's like above look much better .
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
Posted: Thu Apr 28, 2011 1:12 am |
L18LTM wrote: |
**this is a post for a friend not the owner of this account ** |
Why doesn't your friend signup? It's not like it's going to cost anything.
As said H7 55w, not 100w as you risk melting the headlamps and cables.
SMD led all the way.
Posted: Thu Apr 28, 2011 3:31 am |
It will have H7 on top of the headlamp if your friend bothered to open the bonnet & actually have a look
Posted: Thu Apr 28, 2011 3:40 am |
| Renault Twingo 1.2 GT TCE, AP Coilovers, 25mm Hubcentric Wheel Spacers (Rear), 16" Speedline Turini Alloy Wheels, Renault Sport Cup Spoiler,, BMC F1 Panel Filter, Forge Dump Valve, Front Mounted Intercooler, K-Tec SS Cat-Back Exhaust System, K-Tec Decat Pipe, K-Tec Remap. 136.6 BHP 154.3 lbs/ft. | |
Posted: Thu Apr 28, 2011 3:44 am |
i have a 51 plate gti but it has crystals would that be h7 aswell or h4?
Posted: Thu Apr 28, 2011 3:51 am |
doughboy5 wrote: |
i have a 51 plate gti but it has crystals would that be h7 aswell or h4? |
Do you have 1 bulb that operates as dipped/full beam? or do you have 2 separate ones?
Posted: Thu Apr 28, 2011 4:02 am |
If your bulb has 2 pins then it is H7, 3 pins is H4, 1 pin H1.
As MrBSI said, it should listed on top of the headlamp.
Posted: Mon May 23, 2011 3:45 pm |
Depending on the year but if its 2003 on then it should take H7 bulbs (2x pins on the base). We stock a variety of headlight bulbs for the 206 here at www.auto-lites.co.uk/s...rch&page=1
We also off 206info member discount. reply if interested an I cans end the voucher code.
Posted: Mon May 23, 2011 3:57 pm |
Trade Rating: +45
I have these for sale if intrested they have never been taken out of the box, and are still in the packaging that they got sent to me in, cheers
cgi.ebay.co.uk/2x-PHIL...3f02d6f555
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK  | |
Posted: Mon May 23, 2011 3:59 pm |
auto-lites wrote: |
Depending on the year but if its 2003 on then it should take H7 bulbs |
Late 2003 when phase 2 came out is the cross over point, low spec early 2003 cars still rolled out the factory with the frosted H4 type headlights
My feb 03 built 206 had frosted H4 headlamps when it rolled of the production line.
Posted: Mon May 23, 2011 4:04 pm |
Yeah think you are right there. Always good to check what you have in the car/user manual also as sometimes the guides we have have some slight discrepencies. Anyhow whatever you need in terms of lighting, hosing, wipers etc we will stock in our store. As mentioned we can offer 206info members some discount.
Posted: Mon May 23, 2011 4:10 pm |
For the 206 the bulb type needed is on top of the headlamp, unfortunately most people are to dam lazy to have a look
