Latest: tbafonso
Overall: 17130
Online Now [67]:
Visitors: 65
Members: 1
Today: 15606
Total: 104140389
Forums › The Car › 206 Talk › Passenger can hit the brakes now?
Go to page Previous  1, 2
PostPosted: Fri May 27, 2011 2:50 am Up
bisphenol-a wrote:
what about those 206's in australia ?
right hand drive too..
The brake transfer linkage will be the same as a UK spec right hand drive 206.
dalton-gti-180
PostPosted: Fri May 27, 2011 4:09 am Up
isent it were there all built left hand drive then converted..... to check just sit in the passenge seat stick your foot around till you find a bar tap it with your foot and watch the drivers pedals move Very Happy
your defeat now is your victory in the future
myke
PostPosted: Fri May 27, 2011 4:25 am Up
i just went out to my car and literally tapped everything my foot could find, nothing happened, although mines 2005... probably just me can't find it lol, admiteddly it moved a tiny bit when i tapped one bit but not as much as in one of the videos ive seen!
PostPosted: Fri May 27, 2011 4:27 am Up
The 206 was originally designed as left hand drive.
A lot of cars use brake transfer linkages, older Fiesta's as an example but there linkage is inside the engine comparment.
gixxerkev
PostPosted: Fri May 27, 2011 5:47 am Up
Tried it in my 2003 206, tapped n pushed around in the passenger footwell for 5 minutes, no dramas at all.
An Ex '03 1.4 GLX driver, German technology all the way now.
Golfguy206
PostPosted: Fri May 27, 2011 6:28 am Up
if you poke your head under the passenger footwell and look upwards towards the centre console, you can see (on pre 2005 206's) a grey/metal column running along the front of the passenger compartment toward the drivers side - this is the brak trasnfer linkage.
It has the break light switch attached to it (so when you brake, the switch is opened and your brake lights come on)
Original Info member since June 2006.
2002 (plexed) China Blue 206 1.6 XSi - but it needs Coilovers!!
Page 2 of 2
