Posted: Fri May 27, 2011 7:04 am |
Oh god its not a 206 with this problem again....
My little 1.4 LX has had a knock from the front right side since they day it was bought. Lately it has just been getting worse and worse so thought its about time to do something about it. Had a look and the bushes on the drop links had a few splits in them. So last night changed it and it has gone a lot quieter, its not every slight change in angle on the roads there's a horrible clunk. I even managed to come along my street last night without waking everybody up
But I do still have a slight knock there, I think the next thing is the top mount needs changing. Is this a hard job to do?
Also Would this explain the knock that I have when on full lock or would that be something else again?
Posted: Fri May 27, 2011 7:10 am |
I was going to suggest changing the top mount... but if you're planning on doing it anyway I'll shutup
| Renault Twingo 1.2 GT TCE, AP Coilovers, 25mm Hubcentric Wheel Spacers (Rear), 16" Speedline Turini Alloy Wheels, Renault Sport Cup Spoiler,, BMC F1 Panel Filter, Forge Dump Valve, Front Mounted Intercooler, K-Tec SS Cat-Back Exhaust System, K-Tec Decat Pipe, K-Tec Remap. 136.6 BHP 154.3 lbs/ft. | |
Posted: Fri May 27, 2011 8:32 am |
It will be top mount i had mine done few months ago , same noise
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
Posted: Fri May 27, 2011 9:14 am |
How big a job is it to change?
Posted: Fri May 27, 2011 10:13 am |
Could be the bushes on the wishbones. While we are no the subject how much extra time does it take to do when the springs are out? I might do mine when I get it lowered.
Posted: Sat May 28, 2011 9:47 am |
well cost me bout £150 at a garage if it is same ,
probably get it done for cheaper though
Posted: Sat May 28, 2011 9:57 am |
LeeThr wrote: |
Thanks |
if it's top mount bearing then you will hearing the nise whenever you turn the steering wheel.
