Latest: Beduff1977
Overall: 17134
Online Now [410]:
Visitors: 409
Today: 50674
Total: 109221607
Forums › The Car › 206 Problems › drivers doorseal above 70mph.
flat-eric
PostPosted: Sat Jun 04, 2011 3:00 pm Up
hi, the driversdoor seal on my sw tends to whistle and flute above 70mph, is this a simple seal replacement? it looks ok on inspection.
Rob
206SW 2.0 HDI - mods to follow
cartoonhead
PostPosted: Sat Jun 04, 2011 3:03 pm Up
open your door and put your window down and starting at the curved part pull along the top of your door back towards the seal slightly.
you will probably find the leak is only on the curved part.
-xkellatronx-
PostPosted: Sat Jun 04, 2011 3:42 pm Up
my 206cc passenger window does this but mine looks as though window doesnt sit right
Facebook: www.facebook.com/kelly.tompsett
cartoonhead
PostPosted: Sat Jun 04, 2011 3:45 pm Up
has any of the window seal come out of place ?
-xkellatronx-
PostPosted: Sat Jun 04, 2011 3:56 pm Up
you can lift the window higher than it sits when fully closed havent had a change to check seals
but i think its not on the runner properly
cartoonhead
PostPosted: Sat Jun 04, 2011 4:01 pm Up
get a torch and look at the front and back of the glass and see if its jumped out.
if not the only other way would be to remove the door card Sad
craigdmjv
PostPosted: Sat Jun 04, 2011 4:12 pm Up
cc owners seem to be popping out from every where on here lol im one too.... i parked half up a curb the other day and the pass window was above the seal then popped back in after a couple of seconds i fort it was well cool but not doing it again
-xkellatronx-
its not a massive problem ill fix it when i get 5 mins!!
