Online Now [79]:
Visitors: 78
Today: 99007
Total: 105427425
Forums › The Car › 206 Problems › Light Problem
Light Problem
lmilligan
PostPosted: Fri Jul 08, 2011 1:55 pm Up
Hi there I have come across an odd problem with my lighting, my passenger side high beam light doesnt work. Ive done all the obvious such as change the bulb, check its wired properly but it just doesnt work. The dipped beam on the same side still works even though they are on the same cable? I will be grateful for any other suggestions thanks!
PostPosted: Fri Jul 08, 2011 2:09 pm Up
Fuse?
Checked if there is +12volts coming to the bulb?
elcamino
PostPosted: Fri Jul 08, 2011 2:12 pm Up
Connections behind the bulb?does power exist there when high beam selected?
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
lmilligan
PostPosted: Fri Jul 08, 2011 2:15 pm Up
I have checked the fuse and its ok, I will have to get a multimeter and test them on the weekend, thanks a lot guys!
PostPosted: Sat Jul 09, 2011 1:53 am Up
Is it because it's a motorbike and doesn't actually have a light there?
Sorry couldn't resist, vehicle details can be useful at times.
Don't check the fuse by eye, use a multi meter.
