Latest: Beduff1977
Overall: 17134
Online Now [770]:
Visitors: 769
Today: 44397
Total: 107704651
Forums › The Car › 206 Talk › Engine flush
Engine flush
stu_gti180
PostPosted: Thu Jun 23, 2011 6:57 am Up
Ive always put my gti 180 in the peugeot garage for its services... but im going to do it myself....
I understand that 5.3L 5w 40 is to be used, but when looking at an old service reciept 10w 40 had been used... will this of damaged the engine?
also... engine flushing.... any recomended additives?
Gti 180, 04, Janspeed cat-back system, viper induction.
Big_Rich180
PostPosted: Thu Jun 23, 2011 7:03 am Up
The 10w 40 will not have damaged the engine and you dont really need any additives or engine flushing.
Seb
PostPosted: Thu Jun 23, 2011 8:15 am Up
Staff - Seb
Just drain the oil into a catch can, fill it back up with 10w40, it's a better oil for road cars anyway.
PostPosted: Thu Jun 23, 2011 9:44 am Up
DONT!
Engine flush causes more trouble then its worth Wink
The correct oil & genuine / Purflux oil filters being used is much better for the engine then chucking flush bodging stuff in there.
PostPosted: Thu Jun 23, 2011 10:15 am Up
Shove some cheap oil (if that exists anymore) in it and drive it gently for a couple of miles. Then drain it out.
PostPosted: Thu Jun 23, 2011 10:22 am Up
if you are worry you can always wash it with clean oil. Laughing
