Posted: Fri Jun 28, 2013 3:56 pm |
So the axle company supplied the axle with red torsion bars? 180 bars are normally black. Have they provided the right spec axle? Does it come with the correct anti roll bar?
Posted: Sat Jun 29, 2013 10:44 am |
yeah. its the correct axle and torsion bars, when they refurb them they paint them, i just didnt want red lol.
Posted: Wed Jul 03, 2013 1:19 pm |
a few more bits painted
Posted: Thu Jul 04, 2013 9:32 am |
What paint did you use to spray the engine cover? Did you primer/lacquer aswell?
Wouldn't mind doing that to mine as looks mint
| Image removed due to size | |
Posted: Thu Jul 04, 2013 4:41 pm |
some more done today, all wire brushed, rust treated then undersealed with wax oil
Posted: Thu Jul 04, 2013 4:45 pm |
cheers : ) the paint was from a local motor spares. its not made in house they send out for it. and just normal primer/lacquer
Posted: Thu Jul 04, 2013 7:05 pm |
Was it expensive ? I could really do with some as been roying idea aswell as others
Posted: Fri Jul 05, 2013 12:36 am |
no more than £20, but after using others its worth it. ill get name tonight when i come home.
Posted: Sun Jul 07, 2013 2:36 pm |
nice one cheers buddy
Posted: Tue Jul 09, 2013 5:40 am |
anyluck on the name yet pal?
Posted: Fri Aug 23, 2013 1:02 pm |
cars back, almost put back together. if weathers fine tomorrow ill put rest back together and give it a clean for a pic.
Posted: Tue Aug 27, 2013 8:23 am |
Posted: Thu Nov 07, 2013 9:28 am |
Posted: Sat Nov 09, 2013 7:03 am |
Nice clean example you have there mate.
Posted: Sun Mar 09, 2014 8:17 am |
