Online Now [519]:
Visitors: 518
Today: 19314
Total: 106213543
Forums › The Car › 206 Problems › **BRAKE LIGHT PROBLEM**
tomalt
PostPosted: Fri Jun 24, 2011 7:02 am Up
Hi, the top break light is in fine working order, but the rear left and right brake lights are not working(Bulbs are working). Has this happend to anyone, if so is there an easy soloution? Cheers Tom.
Alton 206 Quik 1.4 16v
Abzynthe
PostPosted: Fri Jun 24, 2011 7:10 am Up
East Area Rep - Abzynthe
You might need to clean the connection between your light clusters and the car.
tomalt
PostPosted: Fri Jun 24, 2011 7:31 am Up
thanks, any other ideas?
PostPosted: Fri Jun 24, 2011 7:57 am Up
Bulbs blown.
Incorrect bulbs.
Incorrectly fitted bulbs.
Clusters not connected correctly.
Metal tabs in the bulb holder not making contact with bulb terminals.
Take your pick
PostPosted: Fri Jun 24, 2011 8:17 am Up
Poor connection on switch in passenger footwell.
Had this issue with a 1.1 206, I tried taking the switch out, but as I wiggled it, both started working again.
PostPosted: Fri Jun 24, 2011 8:18 am Up
Aint gonna be the switch Wink
20619d
PostPosted: Fri Jun 24, 2011 8:26 am Up
fuse maybe?
Abzynthe
PostPosted: Fri Jun 24, 2011 8:28 am Up
im sure the brake lights are on separate fuses, and are linked with other things. If the 3rd brake light works, then the driver side one should aswell.
PostPosted: Fri Jun 24, 2011 8:44 am Up
But that's what I thought.
Top one was working, left wasn't and right one was intermittent.
PostPosted: Fri Jun 24, 2011 9:10 am Up
Changed the rear lights by any chance?
Its not the fuse, switch or earthing points.
Its the connector on the lights or the lights themselves.
tomalt
PostPosted: Fri Jun 24, 2011 1:12 pm Up
cheers guys
tomalt
PostPosted: Mon Jul 04, 2011 4:32 pm Up
still not working any idea guys, i havnt got a scooby what wrong with them :/ x
PostPosted: Mon Jul 04, 2011 4:54 pm Up
Run +12v direct to the cluster to ensure they work?
