![](themes/base/images/spacer.gif) |
![](themes/base/images/titleTL.gif) |
Forums › The Car › 206 Talk › Is oil listed on Servicebox? |
![](themes/base/images/titleTR.gif) |
![](themes/base/images/titleBL.gif) |
![](themes/base/images/titleBR.gif) |
![](themes/base/images/forums/otl.gif) |
Posted: Wed Jul 06, 2011 12:30 pm |
As the title suggests, is oil, in particular varieties of Total Quartz listed on Servicebox?
I need some Total Quartz / Activa Energy 0W-30 for the 207 CC. I normally get Total Quartz 9000 from AEP Direct but they don't stock the oil for the 207.
It's quite an expensive car to service. A pollen filter is £30! The oil filter is about £13 I think. I'm going to put a K&N panel filter in it rather than keep replacing the standard air filter.
| | ![](images/spacer.gif) |
Posted: Wed Jul 06, 2011 12:50 pm |
Nah it's not. Total's part number is 151524 for 0w-30
Posted: Wed Jul 06, 2011 2:21 pm |
Edward wrote: |
It's quite an expensive car to service. A pollen filter is £30! The oil filter is about £13 I think. I'm going to put a K&N panel filter in it rather than keep replacing the standard air filter. |
That why you need to be in a peugeot trade club with peugeot, service items can get 50 % or more depending model hehe
And they some really really good prices on clutch kit on the trade club gti 180 clutch kit £180 with vat retail to me £100 with vat
Am gona check tomo the prices of these items for the 207 cc on the trade club.
| 206 Gti 180 Cat-camshafts 804's, Cat cams CTPE 002 exhaust vernier pully, RS tuning remap, Cat back janspeed exhaust, K@N Typhoon induction kit- heat wrapped, Exhaust manifold heat wrapped, Goodridge brake flexi's poly bushs in rear lateral arms, blue led speedo convertion, 50mm Eibach sport line springs, ......
180 Doctor
Hemwoods Gti180 / Pug specialist | |
Posted: Wed Jul 06, 2011 2:26 pm |
i find most of the 0w oil are very expensive.
like the 0w/40 and 0w/30; not to mention those 0w/20 for jap car. :s
| ![](themes/base/images/forums/otr.gif) |
