Posted: Tue Jul 12, 2011 11:05 am |
Hi guys,
So basically my car won't start, it will turn over but won't actually start....
I think that my electrics have shorted out as my pal though it would be a good idea to cut my boot interior light to piggy back other light to it! MUG!!!
I didn't see whether he touched the 2 together but I think he did as now my won't fire up...
The radio won't turn on and the lights won't turn on either...
Will a BSI reset work or do I need to check a certain fuse??
Is there anything that I can do??
I've checked a few fuses such as the radio fuse and what not but nothing??
Any help would be appreciated guys!!!
Posted: Tue Jul 12, 2011 11:07 am |
check ALL THE FUSE first.
Posted: Tue Jul 12, 2011 12:52 pm |
Seabook wrote: |
check ALL THE FUSE first. |
Do as he said,because if the 2 wires (+) and (-) touched each other,and cause a short circuit,the first thing that blow up is the fuse,to protect the main items,so since your radio don't work,u need to check the fuse for the passenger compartment,not sure which fuse it's
Posted: Tue Jul 12, 2011 3:54 pm |
Thank you for your help guys, it was indeed just a fuse that had blown, I was looking like a typical man and the only fuse I didn't check was the one that had blown lol?
Car is all okay now :)!
Thanks again guys!
Posted: Tue Jul 12, 2011 4:01 pm |
glad to see everything is sorted.
Posted: Tue Jul 12, 2011 4:13 pm |
gotta love the feeling you get when you replace a fuse and all is good again! Easy, Cheap... ahhh bliss
Posted: Tue Jul 12, 2011 5:05 pm |
Had that problem before. Took a while to figure out.
Posted: Tue Jul 12, 2011 5:11 pm |
What is it that a fuse for an interior light stops the car from starting? Is that just french logic? when i open the door the light doesn't work that's it i cna't use tghe car? Meh
Mitch good to hear you got it sorted
Posted: Tue Jul 12, 2011 5:12 pm |
Dillon wrote: |
Mitch good to hear you got it sorted  |
used to be the same on my old 106, think the stereo and central locking was on the same one aswell
Posted: Tue Jul 12, 2011 5:28 pm |
If a fuse blows it activates the immobiliser in some cases
