Posted: Fri Jul 15, 2011 12:54 pm |
since ive replaced the headgasket on my 206 i keep getting a loud ticking once the engine has warmed up. i have checked the gaps on all the tappets about 3 times in the last 2 weeks but there still noisey. what else could the problem be as its getting rather annoying ?
its still running fine and no problems
its the 1.1 tu1pj engine with 60k on the clock its also had a recent service
| if it dont scuff the ruff it aint low enuf | |
Posted: Fri Jul 15, 2011 12:55 pm |
if changing the oil don't help then that means you will need new lifters
Posted: Fri Jul 15, 2011 12:59 pm |
give it a Forte engine flush.... you have some hydraulic lifter issues
Posted: Fri Jul 15, 2011 1:09 pm |
I had this and it was the cambelt crankshaft bolt was loose. Make sure its 100% tight
| 206 180 rally car in progress. I may not be perfect but there are parts of me that are f£%$ing brilliant | |
Posted: Fri Jul 15, 2011 1:14 pm |
I get this too however mine is noisey when the engine first starts then when it warms up the noise gets quiter! also had full service about 1 month ago
Posted: Fri Jul 15, 2011 4:23 pm |
Mine seems to start ticking when its stood idling for more than 10 seconds e.g when sat at trafic lights when its warm. Not too sure what it is.
Posted: Fri Jul 15, 2011 5:00 pm |
i have the same problem bfs dad has just changed the head and done a service and since then its very tappy and exhaust sounds very raspy! x
Black 206 1.1 V reg (00), 15" Sirocco Alloy Wheels, Colour Coded Sports Bumpers with Fog Lights, Standard Spoiler, Bosch Aerotwins, Phase 2 Rear Lights, Crystal Head Lights, SP Wheel Arches, GTi Fuel Cap, GTi Half Leather Interior, Official 206 GTi Kickplates, GTi Vent Sliders, Phase 2 Boot Handle (with key hole) | |
Posted: Sat Jul 16, 2011 2:55 am |
also i had a look on the internet and found the guide on adjusting them is cylinder 1 gearbox side or pulley side ?
Posted: Sat Jul 16, 2011 3:02 am |
don't think you can adjust the lifters are they are self adjusted
Posted: Sat Jul 16, 2011 3:21 am |
nope there not self adjusting .
Posted: Sat Jul 16, 2011 3:37 am |
gearbox end
Posted: Sat Jul 16, 2011 3:39 am |
ok i also done the tappets on my mates saxo 1.1 and it came out worse with the info i had
valve clearances are- 0.20mm for all the inlet valves and 0.40mm for the exhaust valves
No.1 exaust valve fully open - adjust No.3 inlet and No.4 exhaust.
No.3 exhaust vale fully open - adjust No4 inlet and No2 exhaust.
No4 exhaust open- adjust No2 inlet and No1 exhaust.
No2 exhaust open - adjust No1 inlet and No3 exhaust.
Posted: Sat Jul 16, 2011 3:40 am |
some people are also saying the engine has to be hot? is this right?
Posted: Tue Jul 19, 2011 6:08 am |
I had same problem for months, tried engine flush, tappet lifter the lot. and it just ended up bein a loose spark plug ha
