Posted: Wed Jul 20, 2011 1:48 am |
How easy is it to replace the entire aerial unit on the front of the roof?? mine has broken off past the screw in part
Posted: Wed Jul 20, 2011 2:10 am |
Pull back the headlining and its a couple of 10mm nuts if I remember right.
Posted: Wed Jul 20, 2011 3:42 am |
thanks alot saves expensive main dealer rip off lol
Posted: Wed Jul 20, 2011 6:17 am |
im a cc owner but have no idea i this is behind the map light and undo a bolt
Posted: Wed Jul 20, 2011 12:18 pm |
ChristAlmighty wrote: |
thanks alot saves expensive main dealer rip off lol |
Other garages are more than capable of fitting a new aerial!
