Latest: tbafonso
Overall: 17130
Online Now [52]:
Visitors: 51
Today: 24032
Total: 104213703
Forums › The Car › 206 Problems › Display screen (clock, date, temp) does not show bright ?
vixytrixie
PostPosted: Sun Jul 24, 2011 9:03 am Up
Hey,
So i have had a problem with my top screen, having read thu similar problems i thought it was the bulbs but after taken the case off i found it was working but only showed bright when i pushed the top and left side of the screen back slightly?
I couldn't see anything loose, but didn't want to fiddle with it as i don't know what im doin!?
Any help would be great,
cheers
vicky
peugeot 206, sapphire blue, 2001.
richpowell91
PostPosted: Sun Jul 24, 2011 9:13 am Up
If its a ppt30 display it will probably need a small white block re soldering. Take a look at this guide, only takes a few seconds to re solder it.
206info.co.uk/Forums/v...ppt30.html
Hope that helps.
PostPosted: Sun Jul 24, 2011 9:47 am Up
That will definately be a broken pin issue. As above, the guide should help!!
vixytrixie
PostPosted: Sun Jul 24, 2011 10:46 am Up
oh brilliant, thanks alot, it was really puzzlin me!
PostPosted: Sun Jul 24, 2011 10:47 am Up
DJ, do you still offer a refurb service on these?
PostPosted: Sun Jul 24, 2011 10:52 am Up
well if anyone doesnt have the equipment i will do the fix providing the person pays postage+return postage.
*i cant guarantee the fix working and I am unable to test now I dont have a ppt30 type car
I do have wiring so could potentially test, im just trying to work out how to connect it to a 12v battery though Confused
PostPosted: Sun Jul 24, 2011 11:15 am Up
I've got some connectors and a loom now, I'll try and work out a test rig for you Wink
PostPosted: Sun Jul 24, 2011 11:26 am Up
i connected it to the car battery once and sparks went flying oops Embarassed Laughing
