Latest: Beduff1977
Overall: 17134
Online Now [516]:
Visitors: 515
Today: 176016
Total: 108808048
Forums › The Car › 206 Problems › De-badging problem..
brimbo
PostPosted: Thu Jul 21, 2011 6:40 am Up
I was giving the pug a wash down with the weather being good, and decided to take of the '206' tag on the back, it peeled of mostly, but it left a different shade of paint behind it..
And closer up..
Thats not a smudge next to the '2', just strange reflections Very Happy
Should I just stick the '206' tag back on? Or is there something I can do about it ?
W-reg 1.4 LX
Abzynthe
PostPosted: Thu Jul 21, 2011 6:42 am Up
East Area Rep - Abzynthe
try some t cut and a bit of elbow grease, if there's no change just put the badge back on Smile
Big_Rich180
PostPosted: Thu Jul 21, 2011 6:43 am Up
Scratch-x, you'll probably have to go at it for a while.
brimbo
PostPosted: Thu Jul 21, 2011 6:47 am Up
I'll t-cut at it in a bit, hoping it will come out as I thought this was a nifty mod Very Happy
W-reg 1.4 LX
Antknee
PostPosted: Thu Jul 21, 2011 6:49 am Up
are you sure its paint and not glue? get a rubber pencil eraser on it and rub with a bit of pressure Wink
LiamGTi180
PostPosted: Thu Jul 21, 2011 6:50 am Up
T-cut should work. Mine looked worse than this but after t-cut no marks at all. good luck
meady
PostPosted: Thu Jul 21, 2011 7:09 am Up
Trade Rating: +45
Tht looks like left over glue. Get some petrol a rag and give it a good rub and it will come off
TEAM - I HATE FACEBOOK Smile
brimbo
PostPosted: Thu Jul 21, 2011 7:14 am Up
Just went out armed with a rubber, its definatly paint, I can feel the surface difference when i rub my fingers over it, The boot was re-sprayed around Feb, im assuming the bloke bodged up masking over the tag's, and didnt remove them
W-reg 1.4 LX
-Dave-
PostPosted: Thu Jul 21, 2011 7:19 am Up
Trade Rating: +36
Mine has mark's left, Not as bad as your's but given up on T-Cut, Will be getting it machined out when I can be arsed.
Ex 206 Owner.
iainlovatt
PostPosted: Thu Jul 21, 2011 7:40 am Up
T-cut and polish it out, if there is any glue residue then use white spirits but make sure you wash the white spirits off afterwards.
(My Garage)
brimbo
PostPosted: Thu Jul 21, 2011 7:41 am Up
Stuck it back on, T-cutted the hell out of it with no success, I think the section would need spraying over to bring the paint flush
W-reg 1.4 LX
Antknee
PostPosted: Thu Jul 21, 2011 8:08 am Up
just keep an eye out on ebay for a cheap tailgate, can play around with it then and still have the original spare, dewiper and debadge it if you do that Razz
PugJH
PostPosted: Thu Jul 21, 2011 8:16 am Up
That gap on the right above the rear light doesnt look good.... never seen one like that before.
WIP: Black 1.6 16v XSi
Beauté Noire
Abzynthe
The hinge probably just needs tightening.
brimbo
PostPosted: Thu Jul 21, 2011 8:18 am Up
The whole of that section is slightly out of line, I was in a crash and it deformed all of the rear driver quarter.
W-reg 1.4 LX
