Posted: Fri Jul 22, 2011 2:08 pm |
After returning to my car, I turned on the stereo then locked the doors and noticed the stereo turned off and on again. I though, Oh s**t... here we go again and *click click click* when I attempt to run the engine.
I have noticed it has occurred twice while using this 75w inverter to charge my laptop:
www.homebase.co.uk/web...3EINVERTER
could this be the reason?
my second question is, when I charge the laptop via the inverter while engine is on, smoke starts to show up seconds later but I have had no problems charging it for an hour while engine was off... I was told I can use the inverter for charging laptops anyway...
any thoughts on this please?
Posted: Fri Jul 22, 2011 2:10 pm |
75watts will be the MAX. Whats the constant?
Posted: Fri Jul 22, 2011 2:16 pm |
does that mean peak power? I can only provide you the details from the link, that's all I know about it.
Posted: Fri Jul 22, 2011 2:17 pm |
You will have max/peak and then constant/rms
For example it might be 500 max, but only 150 rms
Posted: Fri Jul 22, 2011 2:22 pm |
That I do not know but obviously will avoid it from now on.
If the answer is I need a higher output watts inverter then it's fine.
Posted: Fri Jul 22, 2011 2:25 pm |
Well you'd have to check the RMS, and the wattage of your laptop
Posted: Fri Jul 22, 2011 2:40 pm |
Yes will get this checked out, thanks for help!
Posted: Fri Jul 22, 2011 6:26 pm |
I thought a battery could last up to 6 hours when engine is off!
I used/charged laptop 1-2 hours while engine was off... at least I know now.
Oopz!
Posted: Sat Jul 23, 2011 4:28 am |
It depends what you're running, I never charge anything when the engine is off, or run the stereo for that matter.
Posted: Sat Jul 23, 2011 4:42 am |
Hang on, it's doing it only when you charge your laptop and you see smoke?! From where?! Am I getting the wrong end of the stick here?
| Hi Mikey
Posted: Sat Jul 23, 2011 6:02 am |
| sillyhilly wrote: |
| Hang on, it's doing it only when you charge your laptop and you see smoke?! From where?! Am I getting the wrong end of the stick here? |
I am also curious of the smokes location!
Posted: Sun Jul 24, 2011 1:14 pm |
The smoke is coming directly off the AC car cigarette adaptor of course
It overheats too much when engine is on.
