Online Now [280]:
Visitors: 279
Today: 15884
Total: 139024853
Forums › The Car › 206 Problems › Economy mode help..
Economy mode help..
L5_UKS
PostPosted: Wed Aug 03, 2011 1:25 pm Up
Just got my old car back from the garage the engine is f**ked, and wont start however its currently in economy mode due to the ignition being on for 30 mins or more, and the garage have left the windows open, but as its in economy mode and wont start i cant put the windows up :(, does anyone know how to override this? or reset the ecu to take it out of economy mode so i can shut the windows?
Luke.
PostPosted: Wed Aug 03, 2011 1:40 pm Up
Windows only need ignition, don't need to be started.
Doesn't the engine crank?
PostPosted: Wed Aug 03, 2011 1:42 pm Up
Mine say eco mode if left unlocked nd not started for a period of time, all you should have to do to get it out is start the engine.
As Lee said does the engine turn over?
L5_UKS
PostPosted: Wed Aug 03, 2011 1:43 pm Up
Ive clicked it to ignition but the windows wont go up, Yeah it cracks but doesnt fire up
PostPosted: Wed Aug 03, 2011 1:58 pm Up
If your windows won't go up then your battery is seriously flat!
Is it a IMMO fault?
Ash
PostPosted: Wed Aug 03, 2011 2:19 pm Up
Is it a IMMO fault?
How can it be if it cranks?
PostPosted: Wed Aug 03, 2011 2:20 pm Up
Ash wrote:
Is it a IMMO fault?
IMMO cuts fuel, not starter
Rob2859
PostPosted: Wed Aug 03, 2011 2:41 pm Up
Lee wrote:
Ash wrote:
Is it a IMMO fault?
If there is not enough power for the windows to even move then the starter is not going to crank.
So with that in mind the battery has enough charge and the windows are not working for some other reason.
PostPosted: Wed Aug 03, 2011 2:43 pm Up
blown fuse? dead window motor?
Rob2859
PostPosted: Wed Aug 03, 2011 2:44 pm Up
I would say the fuse for the electric windows has blown and its caused it to immobilize itself. Replace the fuse and it should be fine.
L5_UKS
PostPosted: Wed Aug 03, 2011 2:51 pm Up
Cheers guys ill check the fuse tomorrow Smile
PostPosted: Wed Aug 03, 2011 2:57 pm Up
Rob2859 wrote:
Lee wrote:
Ash wrote:
Is it a IMMO fault?
He didn't say if it was cranking now and not firing. Or it went to the garage because it was cranking but not firing.
Rob2859
PostPosted: Wed Aug 03, 2011 3:04 pm Up
Lee wrote:
Rob2859 wrote:
Lee wrote:
Ash wrote:
Is it a IMMO fault?
Point taken. I went on the assumption that it was not starting since being at the garage.
ASS-U-ME DOH!!!
