Posted: Fri Aug 05, 2011 7:20 am |
Hi everyone, ive recentlky bought a automatic peugeot 206 Y reg and was wondering if any one could send me a list of what all the warning lights mean as i have some appearing at the moment and dont know what they mean as i havent got a manual for the car
Help is much appriciated
| 2001 automatic peugeot 206 | |
Posted: Fri Aug 05, 2011 7:21 am |
Trade Rating: +45
Mist be the only one in the qorld being a f reg
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK  | |
Posted: Fri Aug 05, 2011 7:23 am |
sorry its a Y reg only had the car a week so havent learnt the reg yet LMAO
Posted: Fri Aug 05, 2011 7:25 am |
Would be easier for you to tell us what lights are actually on.
Welcome by the way
Posted: Fri Aug 05, 2011 7:27 am |
there's a snowflake like light that is flashing with an s light above it they are flashing alternatly
Posted: Fri Aug 05, 2011 7:28 am |
usual gearbox warning light.
need to get the code read.
Posted: Fri Aug 05, 2011 7:39 am |
Posted: Fri Aug 05, 2011 8:00 am |
thanks the manual will definatly help and someone mentioned it may be to do with the gear box looks like another trip to the gagrage
Posted: Fri Aug 05, 2011 8:07 am |
Might just be an old problem that got sorted but the code never got cleared, either way if you get it code read you can see what it says and check it out and clear the codes
Posted: Fri Aug 05, 2011 10:02 am |
Seabook wrote: |
need to get the code read. |
Seeing as its the AL4 autobox these lights are expected to be on most of the time
Why do people buy auto 206's for? the autoboxes are known to be total s**te yet people still go out & waste money on them.
Posted: Fri Aug 05, 2011 10:12 am |
If you bought it from a car sales place then take it back and ask them to sort it
If you bought it privately and don't have a garage in mind then I'd recommend
shakespeare street garage
| Yes I own a CC and I'm neither gay or a hairdresser!! | |
Posted: Fri Aug 05, 2011 10:18 am |
Lee wrote: |
Lee wrote: |
The (AL4) autoadaptive automatic gearbox is lubricated for life .
All that is required is an oil level check at 60000 km .
Despite that, the automatic gearbox has a system for measuring oil quality .
The AL4 autoadaptive automatic gearbox ECU has an oil wear sensor .
For a given time interval, the counter increases by a certain number of units (of wear) depending on the temperature of the gearbox .
When the counter is exhausted, the gearbox ECU informs the driver of the presence of a fault by the flashing of the Sport and Snow indicator lights on the instrument panel .
Using the diagnostic equipment, the technician checks whether or not it is necessary to replace the gearbox oil . |
Posted: Sat Aug 06, 2011 10:10 am |
would this oil wear sensor thing, make the car lose power and cut out and then not be able to start again for about 3-4mins?? as im having this probelm now the warning ligths are flashing then the car lses power i pull over it cuts out i turn it off and then cant turn it on again
Posted: Sat Aug 06, 2011 10:15 am |
Does the STOP light come on on the dash display. If the oil is very low or a faulty sensor is present, the engine might cut to protect the mechanical components.
Sounds like if its loosing power its going into safe mode before the engne cuts out.
You could do with getting the fault codes read asap and then you will know the cause.
Posted: Sat Aug 06, 2011 10:19 am |
the stop light doesnt come on when the engine is on no, yeah ive got to try and get it into a gargae this week and get it sorted want to get some money back of the cheeky mare that sold me the car saying nah its fine nothign major wrong with it pah yeah right!
