Latest: Beduff1977
Overall: 17134
Online Now [544]:
Visitors: 543
Today: 64418
Total: 108587618
Forums › The Car › 206 Problems › Gearbox problem
Gearbox problem
gmk90
PostPosted: Sun Aug 14, 2011 9:24 am Up
Hi
I have a gti 180 2004 reg with 44,000 miles. Earlier today i was driving down dual carrigeway and its suddenly popped out of 5th gear. I havent had any problems with the gearbox before this and has shown no signs of it being on its way out, it goes into every gear no problem at all and even seems perfectly fine with 5th except it keeps popping out. There is also abit of a 'rattley' sound when i change from 1st to 2nd.
Any ideas as to what can be causing this?
Any help will be much appreciated.
Cheers
Graeme
macj
PostPosted: Sun Aug 14, 2011 9:47 am Up
is the cable assy free or is it a bit sticky... could be the travel is not throwing fifth in fully and its jumping out of its detent
PostPosted: Sun Aug 14, 2011 1:51 pm Up
When my GTi was about 14k miles old it had a couple of synchros change which then resulted in the jumping out of fifth when lifting off the throttle. That meant fifth gear needed replacing too.
gmk90
PostPosted: Mon Aug 15, 2011 3:59 am Up
It stays in 5th for a while then comes out randomly, like its not like it wont stay in at all
All i do is win my name should be victor.
