Posted: Mon Aug 15, 2011 2:26 am |
Anyone got a part number for the GTi speed sensor and ABS sensors?
Got a fault on the speed sensor I think and rear left hand ABS sensor.
Posted: Mon Aug 15, 2011 2:27 am |
Also - where is the speed sensor located on the GTi? (Please be in an easy to reach location)
If you want you can come and remove them off my Gti mate
Posted: Mon Aug 15, 2011 2:34 am |
They are located on the rear arm behind the back of the hub, 1 10mm bolt holding it on
Posted: Mon Aug 15, 2011 2:35 am |
kieron wrote: |
They are located on the rear arm behind the back of the hub, 1 10mm bolt holding it on |
Thought speed sensor was on gearbox?
furryhobnob wrote: |
If you want you can come and remove them off my Gti mate |
How much you want for them matey?
Posted: Mon Aug 15, 2011 2:57 am |
Well your a better man than me if you can get an old ABS sensor out undamaged!
| This 206 IS going on a trackday despite it's every effort to stay at home in the garage! | |
Posted: Mon Aug 15, 2011 2:58 am |
D4NTP wrote: |
Well your a better man than me if you can get an old ABS sensor out undamaged! |
Tbh my last 206 had no ABS and I've never even attempted it, was easy on the VX but then again, completely different car...
Posted: Mon Aug 15, 2011 3:00 am |
Well from my attempts they either crumble in your hands or you snap the end off flush with the hole in the hub.
Posted: Mon Aug 15, 2011 3:01 am |
Posted: Mon Aug 15, 2011 3:18 am |
For that price i wouldn't bother getting dirty getting salvage ones.
Posted: Mon Aug 15, 2011 4:01 am |
Yeah, I might give that a go, found some speed sensors too but no idea which one it is!
Posted: Mon Aug 15, 2011 4:10 am |
Seb wrote: |
Yeah, I might give that a go, found some speed sensors too but no idea which one it is! |
Service Box
Stick the VIN number in & it will give you the correct part numbers for the car in question.
Posted: Mon Aug 15, 2011 4:14 am |
61670 speed sensor
454579 rear ABS
454576 front ABS
I just checked online, service box always annoys me as the password keeps getting changed.
Also got a mate that's getting me a copy of Peugeot Planet & the cable which should be good
Posted: Mon Aug 15, 2011 4:16 am |
Seb wrote: |
Also got a mate that's getting me a copy of Peugeot Planet & the cable which should be good  |
That used to annoy me to so I just got my own Service Box account.
Im thinking of getting Planet to BUT I might hold out for Diag Box instead as its backwards compatible with Planet & Lexia.
