Posted: Wed Aug 17, 2011 4:12 am |
hi can anyone help , i have a 3 door 206 and have been finding water under my rear seats , does anyone have a clue on ware this can be coming from !!!!!!!!
Posted: Wed Aug 17, 2011 4:16 am |
I think water comes from black caps you can find under your seats. I had 2 206 and both of them had the same problem. I never looked for a solution...
| Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror | |
Check the window seals
Posted: Wed Aug 17, 2011 5:09 am |
Search the damn website!
| Hi Mikey
Posted: Wed Aug 17, 2011 5:15 am |
At a guess you have lexus lights, they do not seal properly allowing water to run down
This is what happened to me
| Team Impossible Possible
Posted: Wed Aug 17, 2011 6:18 am |
I had the same problem - 2 of the 3 black plastic caps/plugs had deteriorated, and wasn't sealing at all. Instead of buying new plastic caps, I just took some marine grease and filled a lot of it on the caps, and put it back in. Seemed to seal it good enough. Haven't checked for water since though
| 2002 Peugeot 206 GTi 2.0 16v 137Bhp | |
Posted: Wed Aug 17, 2011 10:53 am |
| sillyhilly wrote: |
| Search the damn website! | ,
am sure this section is for 206 problems ,
thanks every1 i will check out they suggestions
Posted: Wed Aug 17, 2011 11:28 am |
If your a pimp... your prostitute needs emptying
Posted: Sat Aug 20, 2011 4:30 am |
[quote="Addaz"]At a guess you have lexus lights, they do not seal properly allowing water to run down
This is what happened to me[/q
problem solved , thanks
