Posted: Fri Aug 19, 2011 1:24 pm |
As titled, can't seem to find it in my handbook, or on the web
Posted: Fri Aug 19, 2011 1:25 pm |
Trade Rating: +59
It's in your handbook in litres.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Fri Aug 19, 2011 1:28 pm |
50 litre tank.
563 ml per pint.
8 pints per gallon
13.2 gallons
See I am useful. Unban me.
Posted: Fri Aug 19, 2011 2:01 pm |
Your maths is terrible.
There is roughly 4.55 litres in a gallon. So that's about 11 gallons.
Posted: Fri Aug 19, 2011 2:06 pm |
roughly 27.2 MPG, thanks guys
Posted: Fri Aug 19, 2011 2:18 pm |
Edward wrote: |
There is roughly 4.55 litres in a gallon. So that's about 11 gallons. |
No it's not you imbecile. There's two kinds of gallons, US and Imperial. OP didn't specify and my calculations are correct as are yours.
Your logic is terrible.
Posted: Fri Aug 19, 2011 2:23 pm |
So there is logic in using US gallons on a UK forum?
Posted: Fri Aug 19, 2011 2:26 pm |
should ban the use of pint, gallon, stone, feet, inch...etc
metric only!
Posted: Fri Aug 19, 2011 2:28 pm |
Edward wrote: |
So there is logic in using US gallons on a UK forum? |
They use US Gallons to quote MPG figures on European cars, so yes there is logic.
It's exactly the same as they use imperial in the US on occasions.
Don't shoot someone down trying to help you cretin.
Posted: Fri Aug 19, 2011 2:31 pm |
Lets go back to pre-decimalisation. Money was worth more then.
Posted: Fri Aug 19, 2011 3:13 pm |
MthomasGTI wrote: |
Edward wrote: |
Don't shoot someone down trying to help you cretin. |
Considering I was asking on a French car forum, ( in europe last I knew ), how many gallons are in a french car, it kind of defeats the need for logic to work it out..
Posted: Fri Aug 19, 2011 3:47 pm |
Refer to previous posts.
You could however have googled it and figured it out yourself. I guess you're just too lazy
Posted: Fri Aug 19, 2011 4:34 pm |
That last post was so important, he had to post it twice!
Posted: Fri Aug 19, 2011 4:42 pm |
Trade Rating: +36
Well he has just lost 2000+. Can't even sell anything at the moment
Posted: Fri Aug 19, 2011 5:19 pm |
Suicidalsoldi3r wrote: |
Well he has just lost 2000+. Can't even sell anything at the moment  |
Especially when I have £100 of their money and don't know their address without going on to PMs!
