Online Now [60]:
Visitors: 58
Members: 1
Today: 11059
Total: 104961428
Forums › The Car › 206 Problems › Centre vent "auto" close
gpvecchi
PostPosted: Mon Aug 29, 2011 1:07 pm Up
It's the second 206 I have and both of them have this problem...
When getting old, center vents close themselves when putting air flow to max.
Is there any way to fix it without changing them?
Thanks!
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
Antknee
PostPosted: Mon Aug 29, 2011 3:50 pm Up
there should be 2 buffer type things between each vent and the wheel thing that you use to open and close them Wink likely that they arent making contact or something, could always stick a bit of insulation tape in to pad it out or something to make it stiffer to close
gpvecchi
PostPosted: Tue Aug 30, 2011 1:09 pm Up
ITanks, but... Am I the one with this problem?
Ash
PostPosted: Tue Aug 30, 2011 1:26 pm Up
Sounds like it. Sure the assembly is all pushed together correctly so the cogs are meshed together?
gpvecchi
PostPosted: Wed Aug 31, 2011 1:20 pm Up
Sure, in both of the 2 cars... It seems that the "click" when I full open the vents is worn-out...
