Latest: Worthy967
Overall: 17143
Online Now [569]:
Visitors: 568
Today: 34399
Total: 115678975
Forums › The Car › 206 Problems › misty windscreen
misty windscreen
lewisr
PostPosted: Mon Sep 12, 2011 3:20 pm Up
new to the French scene, so still getting use to the car, but no matter what settings I seem to put the demist to, I am still left with a thin line of mist along the bottom of the windscreen. any suggestions as to what I should be putting the setting to, to get rid of it. Rest of the windscreen is clear.
Ray
Ray
cartoonhead
PostPosted: Mon Sep 12, 2011 3:30 pm Up
are the heater blowing hot as the heater matrix are prone to blocking.
lewisr
PostPosted: Mon Sep 12, 2011 3:32 pm Up
heaters are blowing hot, everything including the AC seems to be working, just think I might be missing something in the set up, which is leaving this small strip along the bottom.
Ray
PostPosted: Mon Sep 12, 2011 3:38 pm Up
Don't have it on recycled air
Get the AC serviced
lewisr
PostPosted: Mon Sep 12, 2011 3:41 pm Up
not on recycled air, good point about the AC as I don't know when it was last serviced so probably worth doing that.
Ray
Deckchair5
PostPosted: Tue Sep 13, 2011 12:33 am Up
AIR FLOW
Have you cleaned out the cabin air filter? That will severely restrict new air flow.
A/C
Is the A/C actually working well and making it cold in the cabin? If it is then it won't be that causing problems
DIRECTION
When you select front screen demist is the air being blown up there significantly strongly?
HEAT
if you turn the A/C off, select higher temps and turn the fan speed up does it clear it then?
PostPosted: Tue Sep 13, 2011 1:57 am Up
Give the windscreen a good clean. Maybe some residue left on there from last time it was cleaned, or may just be grimey.
If that still doesn't work, go to Halfords and buy Rain-x anti mist. You can get better products from motoerbike shops but Halfords is usually the most accessible.
lewisr
PostPosted: Tue Sep 13, 2011 1:07 pm Up
where is the cabin air filter ?
Ray
Deckchair5
PostPosted: Tue Sep 13, 2011 5:20 pm Up
Have a look here
click here<<
It's not difficult but make a note how you remove it to help you refit it
