Latest: tbafonso
Overall: 17130
Online Now [128]:
Visitors: 127
Today: 10843
Total: 102533650
Forums › The Car › 206 Problems › revs drop when driving
ian89
PostPosted: Fri Jun 17, 2011 12:32 pm Up
encounterd another problem when i am driving i can be slowing down in any gear or speeding up and sometimes when i try to accelertae the revs drop and the engine tries to cut out. this also happend when i was idling in traffic the revs started dropping so i pressed the accelerator to keep them up but the car stalled..
any ideas on problems its a 1.4 lx 98
ian89
PostPosted: Tue Sep 06, 2011 9:49 am Up
well just cleaned throttle body out yesterday failing that going to try the purge valve
ian89
PostPosted: Sun Sep 11, 2011 7:52 am Up
contatcting peugeot garage tomorrow about this now im fed up every time i come to a stop as i put the clutch down the revs just die and the car cuts out only sometimes the revs die and the car goes to stall and they they are saved and idle at about 800
panzer360gti
PostPosted: Sun Sep 11, 2011 1:06 pm Up
when you cleaned the throttle, did you take it off and clean the whole thing? also check around for air leaks, on the intake, on your exhaust, everywhere, I have this problem but have cured it with these steps
Peugeot 206 GTI 137 2.0
ian89
PostPosted: Tue Sep 13, 2011 8:49 am Up
no leaks on the intake have to check the exhaust.
would a leak on the exhaust make the car cut out or the revs drop and rise?
thanks
ian89
PostPosted: Thu Sep 15, 2011 8:14 am Up
could the fuel fillter cause my engine to surge and make the revs drop and make the car cut out?
LWhite92
PostPosted: Fri Sep 16, 2011 2:25 pm Up
Had this problem with mine a few months ago. My 206 is exactly the same year and spec as yours. Striped and cleaned the throttle body out and replace the Idle Air Control Valve and been fine since. Hope this helps mate
Has gone to the dark side!!!
Now driving a Black Magic Skoda Fabia vRS
