Online Now [526]:
Visitors: 525
Today: 24517
Total: 106218744
Forums › The Car › 206 Problems › loose nut behind the steering wheel ?
bisphenol-a
PostPosted: Tue Sep 20, 2011 6:14 am Up
just realised when i was driving back today.. whenever i go over a significant bump on the road or say driving over some rail tracks i hear like a nut/screw sound behind the steering wheel. is it called the comm unit that houses the stalks and all? sounds seems to be coming from there like there is a loose screw that got out of place and is contained somewhere in there but jumping about under the covers. operation and use is all fine like the usual, just the sound is quite a nuisance.
is there a how-to around here? i try searching for comm unit and steering wheel nothing.
PostPosted: Tue Sep 20, 2011 6:39 am Up
i would take the housing off and see if anything is loose, there are few bolts/screws it could be around there.
bisphenol-a
PostPosted: Tue Sep 20, 2011 6:40 am Up
i just stumbled upon a how-to
so just remove the 2 t20 screws from the bottom and start looking?
PostPosted: Tue Sep 20, 2011 6:45 am Up
yer there the ones,
1st thing i would do if it was me.
EdCherry
PostPosted: Tue Sep 20, 2011 7:07 am Up
The only loose nut behind the steering wheel is you, you crazy animal.
