Posted: Thu Sep 22, 2011 12:30 pm |
Hi
I had my MOT today and it was going to fail on the washer jet pump being broken, so the garage replaced it for me.
The jets work again now and spray well all across the screen, but they also seem to be spraying on the bonnet area infront of them too. How can I stop this?
Andrew
Posted: Thu Sep 22, 2011 12:36 pm |
do they just need adjusting up a tiny bit?
or they dribbling as well as spraying (only way i can describe it )
and simple pin would probably sort that out in both cases,
Posted: Thu Sep 22, 2011 12:39 pm |
Are they just adjusted by using a pin? They don't dribble, but they spray on the bonnet runs everywhere
Posted: Thu Sep 22, 2011 12:52 pm |
Trade Rating: +32
Just get a pin and move the outlet up.
Posted: Thu Sep 22, 2011 1:53 pm |
Cheers guys, I wanted info advice before doing anything as I feared using a pin could make things worse
Posted: Thu Sep 22, 2011 2:12 pm |
Andrewxps wrote: |
Hi
Andrew |
Completely normal with phase 2 washer jets, this has been asked before as well.
Im pretty sure that they cant be adjusted as well.
Posted: Thu Sep 22, 2011 2:16 pm |
Mikey2uk wrote: |
Andrewxps wrote: |
Hi
Andrew |
Im pretty sure that they cant be adjusted as well. |
Correct - they cant be adjusted, wonder if they are actually 206 jets or ones from another Peugeot / Citroen
Posted: Thu Sep 22, 2011 2:18 pm |
Trade Rating: +36
His is a late 206 so would be the standard phase 2 that came with it I would Imagine.
Posted: Thu Sep 22, 2011 2:26 pm |
Yes its a phase two model so its not a case of switching from phase 1 to phase 2 jets
Posted: Thu Sep 22, 2011 2:27 pm |
Completely normal and nothing to worry about.
I have now treated my screen so very rearly use my washer now as its got a self cleaning agent on it.
Posted: Thu Sep 22, 2011 3:02 pm |
Ooo goodie I will have to look into that
