Online Now [312]:
Visitors: 312
Today: 47492
Total: 105941509
Forums › The Car › 206 Talk › Fitting new idle control valve
PostPosted: Mon Oct 31, 2011 7:56 am Up
How easy is it to fit a new idle control vlave? Where is it located in the ph1 Gti engine and is there anything else required after it is installed? Been quoted £197 to supply and fit a new unit but seen them online for less than £30 and if it's an easy job, i'd rather do it myself and save myself alot of money
PostPosted: Mon Oct 31, 2011 8:16 am Up
Remove the throttle body cover.
Its the one at the top right in the pic.
PostPosted: Mon Oct 31, 2011 8:26 am Up
Screwdriver to undo the jubilee clip on the plastic throttl ebody cover. Then 2x torx screws to get the ICV off. Get some carb cleaner to blast out the hole it sits in.
I've got one somwhere. Fancy it for £10+postage? I'm never going to use it.
PostPosted: Mon Oct 31, 2011 8:32 am Up
what sort of condition is it in Ed?
PostPosted: Mon Oct 31, 2011 9:52 am Up
Well it's very clean.
PostPosted: Mon Oct 31, 2011 10:02 am Up
ok mate, can send payment thursday
