Online Now [149]:
Visitors: 147
Members: 1
Today: 19392
Total: 117269333
Forums › The Car › 206 Problems › 206 XSI cold start problem
whiteTRD
PostPosted: Thu Nov 03, 2011 9:52 am Up
Hi Guys,
First Time poster, I have heard from a friend that you were the gang that could help me out. I have a 206 XSI 2003 facelift model. During cold weather I can get into the car, go to start, starts fine but sounds like its choking. Then cutsout, I have to give it a good rev for it to stay on. Sounds like a temp sensor or fuel pump could I be right?
Regards
Caoibhin
PostPosted: Thu Nov 03, 2011 11:04 am Up
First port of call....get the battery tested.
Second when was the last time it had a proper service?
Third clean the ICV
Forth Temp sensor at about 25oC should be 2392ohms and gets lower to 144ohms @ 100oC as the engine gets hotter
