Posted: Sun Nov 06, 2011 4:43 am |
Trade Rating: +46
Well a rust topic on 2004 206 gti 180 sure most other models will be the same..
my partner and i were inspecting a new gti 180 we purchesed and came across some serious corrosion in front wheel arches right on seams we checked the old trackie and that was even worse.. must be common ...
pics will follow... some time today really shocked with outcome...
Posted: Sun Nov 06, 2011 4:47 am |
chance to try and find some carbon fiber replacements
Posted: Sun Nov 06, 2011 4:59 am |
Trade Rating: +46
rust is in inner wheel wells under arch linings termanal
Posted: Sun Nov 06, 2011 7:02 am |
could it be a bad repair job?
Posted: Sun Nov 06, 2011 7:09 am |
Trade Rating: +46
never been damaged...
Posted: Sun Nov 06, 2011 7:23 am |
interesting....
will have a check on mine...
Posted: Sun Nov 06, 2011 8:02 am |
Is it the same on both sides?
Posted: Sun Nov 06, 2011 8:06 am |
Trade Rating: +46
yer and on x2 cars if i had a 3rd ide check that aswell.. 206 gti 180 03 plate gti180 04 plate... both same places..
Posted: Sun Nov 06, 2011 10:37 am |
It's common to have some corrosion there. Although to have perforated the whole way through is a bit bad.
Posted: Sun Nov 06, 2011 10:47 am |
Trade Rating: +46
mmmm on x2 cars aswell carnt bring myself to check the sw,,
Posted: Sun Nov 06, 2011 11:08 am |
just weld it up and waxoyl it mate thats what my son does with his cinq
Posted: Sun Nov 06, 2011 11:28 am |
My track 206 had the same, although not as bad as that
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner | |
Posted: Sun Nov 06, 2011 11:42 am |
Trade Rating: +46
strange for a newishish car,s
Posted: Sun Nov 06, 2011 11:54 am |
How long is the anti perforation warranty on these? That might still be covered...if the warranty hasn't been voided that is.
Posted: Sun Nov 06, 2011 11:55 am |
Edward wrote: |
How long is the anti perforation warranty on these? That might still be covered...if the warranty hasn't been voided that is. |
Doesnt there have to be a yearly inspection at a Peugeot main dealer for the anti perforation warranty to be valid?
