Latest: Puggingalong
Overall: 17129
Online Now [151]:
Visitors: 150
Today: 9054
Total: 101431257
Forums › The Car › 206 Problems › is it head gasket blown?
joker83
PostPosted: Sat Nov 12, 2011 8:20 am Up
imageshack.us/photo/my...11406.jpg/
was looking at the engine today and saw this,there is no oil in water,no mayo in oil cap,no overheating.does it looking really bad? cheers.what to do with it?
gti 2.0
dumdum0910
PostPosted: Sat Nov 12, 2011 8:25 am Up
that just looks like the rocker cover gasket is leaking . to replace you need to take the rocker cover off and place a new gasket
joker83
PostPosted: Sat Nov 12, 2011 8:27 am Up
so i need only new rocker cover gasket or bolts as well,is it straight forward,unscrew,clean it new gasket,then bolts back thats it?cheers
gti 2.0
dumdum0910
PostPosted: Sat Nov 12, 2011 8:35 am Up
you shouldnt have to replace the bolts but you can do if you want to go that far and the rest pretty much spot on
PostPosted: Sat Nov 12, 2011 8:43 am Up
2 rocker cover gaskets on a GTI Wink
joker83
PostPosted: Sat Nov 12, 2011 8:50 am Up
so what to do now mate step by step please if u can please
gti 2.0
PostPosted: Sat Nov 12, 2011 8:52 am Up
Visiting a Peugeot / Citroen main dealer parts dept & exchanging money for the gaskets required is the first step.
joker83
PostPosted: Sat Nov 12, 2011 8:59 am Up
oh my god gaskets i can buy thats not a problem im asking how to change them cheers
gti 2.0
macj
PostPosted: Sat Nov 12, 2011 10:04 am Up
I would check the cam carrier gasket too..... thats below the cover gasket. Best to clean everything up before you pull it apart, Then you may see where the oil is coming from when you run it again
joker83
PostPosted: Sat Nov 12, 2011 10:13 am Up
i dont think its been cleaned ever before so will do that first.anyway this cover looks like its not properly sits there, there is very small gap on the photo,from coil pack side thank you for answer
gti 2.0
M60SHW
PostPosted: Sat Nov 12, 2011 12:24 pm Up
www.amazon.co.uk/Peuge...1859607578
Team, ST
Team, Gti 138 track slag
