Latest: flipflap
Overall: 17140
Online Now [335]:
Visitors: 334
Today: 21336
Total: 113821531
Forums › The Car › 206 Problems › Front demister
Front demister
Taff!
PostPosted: Mon Nov 28, 2011 4:13 am Up
Don't know if it's a fault or not but when I put on the front demister/blower as per the instructions ie turn up to 28 and then press the the demister button I'm expecting hot air to be coming out the windscreen vents rather than just normal temperature air. Air con seems to be working fine at low temperatures . Is this right or is there something wrong, just want to get it sorted if so before we have a proper frost.
206 1.6 Quiksilver
PostPosted: Mon Nov 28, 2011 7:36 am Up
Assuming you've let the engine warm up first?
oldskoolz
PostPosted: Mon Nov 28, 2011 10:37 am Up
LOL
Black 206 Gti. Soon to be 2.2
PostPosted: Mon Nov 28, 2011 10:58 am Up
Take it pollen filter has been changed on time?
Taff!
PostPosted: Mon Nov 28, 2011 3:11 pm Up
Yes pollen filter changed. The fan is fine at temperature if the engine is heated I can put the fan position to windscreen and it will clear quickly. I'm talking about the auto demist function that kick the AC function on - I've never found any difference between whacking the fan on full and directing it to the windscreen outlets compared to the auto other than auto using A/C
206 1.6 Quiksilver
PostPosted: Mon Nov 28, 2011 3:21 pm Up
Digital climate control?
AC & AUTO settings both use the air con system to help dry the air.
Front demist button just fires up the rapid demist program.
If you stick it in ECO its just a plain normal heater.
Taff!
PostPosted: Mon Nov 28, 2011 3:32 pm Up
Yes it's digital. That explains it. Thanks for that.
206 1.6 Quiksilver
PostPosted: Mon Nov 28, 2011 4:19 pm Up
The A/C does help to clear the window quicker as well.
