Online Now [542]:
Visitors: 541
Today: 13067
Total: 105590070
Forums › The Car › 206 Problems › 206 GTI 180 Anti Polution Fault
Go to page 1, 2, 3  Next
nellyhaggis
PostPosted: Tue Dec 14, 2010 9:58 am Up
Afternoon all,
My 206 GTI 180 has just decided to bring up the dreaded 'antipolution fault'.
Its been running ok but sometimes seems a little slugish when you put your foot down before the power really comes in.
Also if you pull up at a junction it sometimes revs at about 1200 rpm before settling down to it usual 800 rpm.
If anyone has had a similar problem with there's I would be very gratefull for some help of any kind.
Cheers.
- Sinature removed due to size.
Please feel free to upload one of the correct dimensions.
Big_Rich180
PostPosted: Tue Dec 14, 2010 9:59 am Up
unplug your VVt solenoid then plug it back in, sorted mine.
Or it could be a Lambda sensor on the exhaust but my first suggetsion wont cost you anything Laughing
nellyhaggis
PostPosted: Tue Dec 14, 2010 10:00 am Up
What is the VVt solenoid?
Big_Rich180
PostPosted: Tue Dec 14, 2010 10:03 am Up
If you take the engine cover off, and look towards the back lefthand side of the engine, you will see some wiring going to the solenoid, just unplug it.
The VVT solenoid is what controls the variable Valve timing, so it will run like crap when it doesnt work.
Where abouts in sheff are you from?
PostPosted: Tue Dec 14, 2010 10:10 am Up
Big_Rich180
Cheers Lee
nellyhaggis
PostPosted: Tue Dec 14, 2010 10:28 am Up
Cheers lads.
I will fish the spanners out tonight and have a fiddle around with it.
Are these are a comon fault then?
And ive been reading a few older posts and am I right in thinking that the ecu fault will need to be cleared from the car for it to run properly again?
Iam in Crooks. Do you fancy fixing it then?
Ive got an annouying bloody squeek coming from the dash somewhere too. Its going to drive me bloody nuts if I dont find it and cure it soon.
Big_Rich180
PostPosted: Tue Dec 14, 2010 10:30 am Up
nellyhaggis wrote:
Cheers lads.
If it is the VVT solenoid the fault code should clear its self, i was thinking i could help you if we met up but its a really simple task and doesnt need 2 people really.
nellyhaggis
PostPosted: Tue Dec 14, 2010 10:37 am Up
I was only joking.
I will have a look at it tonight when iam in work.
Doubt it will be as simple as unplugging and plugging back in again thou.
But defo worth a shot.
You got any ideas about the squeek?
Big_Rich180
PostPosted: Tue Dec 14, 2010 10:38 am Up
nellyhaggis wrote:
I was only joking.
It worked on mine mate.
Could be mouse Laughing
Just leave it for a week it will stop eventually, its french...they all squeek Laughing
kieron
PostPosted: Tue Dec 14, 2010 10:44 am Up
the fault will always be stored even if the vvt is replace it would come up as pending fault insted of stored
when the vvt is a fault it loses all power its like driving a 1.1! when mine was at fault it woulnt idle because it snaped in 2 pieces so i un[luged it and run sweet but realy realy slow
Account suspended
Big_Rich180
PostPosted: Tue Dec 14, 2010 10:48 am Up
It will stay as a fault logged on the ECU but the light on the dash will disapear.
nellyhaggis
PostPosted: Tue Dec 14, 2010 10:51 am Up
Well first things first anyways.
I will try the vvt.
If its that i will have a trip to pug for them to remove the fault.
You aint heard a squeek like this. Its driving me nuts.
I thought it was theheater fan but it still does it with the fan off.
nightmare.
PostPosted: Tue Dec 14, 2010 10:54 am Up
I'll clear the code for £20, and I'll meet you in town somewhere.
Ali_H
Clean the VVT solenoid with carb cleaner while it's out. It's a 5 minute job.
It may also be a sensor in the exhaust bringing up the antipolllution fault.
Page 1 of 3
