Latest: Puggingalong
Overall: 17129
Online Now [146]:
Visitors: 145
Today: 8847
Total: 101431050
Forums › The Car › 206 Problems › cream in oil filler cap
wayne-o-mac
PostPosted: Mon Dec 05, 2011 1:45 pm Up
hi was checking my oil at the weekend on my 206 gti 180 to find a small amount of white cream in the very top of the cap,
just wondered if this is common on these engines and also i changed the rocker gasket a couple of days before and wondered if it's possibly got sme moisture in and it's just condensation and not the headgasket on the way out??
ive checked the coolant and oil and it hasn't lost any of either
any ideas/help would be much appreciated
p.s would post a picture but couldn't figuer out how to do it lol
206gti180 black
shell-vt
PostPosted: Mon Dec 05, 2011 1:46 pm Up
Trade Rating: +46
could be condensationjust.. check header tank for bubbles and oil..
york 16,3
PostPosted: Mon Dec 05, 2011 6:01 pm Up
Short journeys mean the engine doesn't warm up enough so condensation is sometimes produced. This can manifest as a 'creamy' or 'mayonnaise' type substance on the filler cap. These short journeys aren't good for an engine but as long as the oil & filter is changed regularly shouldn't be to much of a problem. A good sound thrashing once a week should also help to evaporate any condensation as well (more fun than an oil change as well Smile )
Or your head gasket has gone kuput in which case it's gonna get expensive.
PostPosted: Tue Dec 06, 2011 2:05 am Up
It doesn't need a thrashing, just need a decent 30 minute run.
Barking
PostPosted: Tue Dec 06, 2011 2:59 am Up
it's a 180 - it's built for thrashing Wink
I got a dig bick.
You that read wrong.
You read that wrong too.
PostPosted: Tue Dec 06, 2011 3:04 am Up
Well said Laughing
wayne-o-mac
PostPosted: Fri Dec 09, 2011 4:30 am Up
thanks for the replys guys,
have been checking it all week and it's lost no coolant at all but a bit of oil got a bit worried then i noticed that it was coming from around the oil filter so got a new 1 and gave it a service too and all seems good, hopefully it was just condensation
206gti180 black
