Online Now [48]:
Visitors: 47
Today: 7560
Total: 106137301
Forums › The Car › 206 Problems › Knocking From Back Wheels When Breaking
jonathonccs
PostPosted: Sun Dec 04, 2011 6:12 pm Up
I have a 1998 1.4 206. When I brake there is a knocking noise coming from the driver-side rear wheel. The harder I break, the louder it is.
Any help will be appreciated as the frost weather is coming.
JJ
Rob2859
PostPosted: Sun Dec 04, 2011 8:41 pm Up
Jack the car up, give the wheel a hard shake and a pull and push to see if there is any play. see if the tyres have work unevenly.
steve01
PostPosted: Mon Dec 05, 2011 3:39 am Up
also check the wheel nuts are torqued correctly its amazing how people overlook this.
yeaaahhhh baby diesel power
ukskater01
PostPosted: Mon Dec 05, 2011 8:39 am Up
Have you got discs on the rear? Not sure if it would be the same but my front brake caliper seized on one side. It made a lot of noise when braking just like yours. Took the wheel off and the piston was stuck so only one pad was working.
It wouldn't hurt to have a look
gazza82
PostPosted: Mon Dec 05, 2011 9:57 am Up
Unlikely to be discs on a '98 1.4. Drums probably. Not so easy to inspect as you have to destroy the hub nut to get it off and replace it.
A common problem is the brake shoe linings come away from the shoes ..
Rob2859
PostPosted: Mon Dec 05, 2011 10:07 am Up
I got a knocking noise when braking once and it took be a few days to realise I forgot to tighten the bolts up when I dropped the car down Embarassed
When I had my axle done the drums were taken of and the shoes just fell out Very Happy
jonathonccs
PostPosted: Wed Dec 07, 2011 8:10 am Up
No, the car has drums. Nuts are all fine too. I'll have a look at the shoes tonight and let you all know.
JJ
