hi all, just a quicky
each time when i first set out in the car of a morning the gear shift would pop strait out of first and into neutral when i press down the clutch pedal, it has done this for the last 3 or 4 mornings now, it doesnt really bother me because this is the only time it does it, but i may want to replace whatever is causing this just in case it gets even worse.
if somebody could shed some light on this for me i would be very gratefull
