Posted: Mon Dec 19, 2011 7:52 am |
hi any suggestions of what turbo should i us erm t3?? t3/4 ?? and what injectors i have tu use along with a remap obviosly...10x allot..
Posted: Mon Dec 19, 2011 11:26 am |
t3 or even t3/4 you will have a huge turbo lag, not good on a low rev diesel
Posted: Mon Dec 19, 2011 12:09 pm |
mm tought so as well..... what do you think is the ideal??
Posted: Mon Dec 19, 2011 12:17 pm |
what kind of power are we talking about?
Posted: Mon Dec 19, 2011 12:19 pm |
im my mind i hve a progect that is 150-160 bhp i know how to go in that area but i tought to climb up a bit more..mabe 180...??...thats why i tought of a larger turbo..
Posted: Mon Dec 19, 2011 12:30 pm |
then you have no choices.
plus you need to find a good mapper too.
Posted: Mon Dec 19, 2011 12:46 pm |
What turbos are used on standad 2 litre diesels that make 180 bhp?
Posted: Mon Dec 19, 2011 1:20 pm |
Edward wrote: |
What turbos are used on standad 2 litre diesels that make 180 bhp? |
bmw 320d are about that ???
you will need vnt turbo ,fmic, upgraded fuel pump maybe from a 320d thats what a few people on tdocuk use, also stage 3 remap, decat, de-egr.
then other mods like bigger breaks free flowing exhaust
best part of 2k is it worth it?
Posted: Mon Dec 19, 2011 1:38 pm |
A 20litre engine'd car should be more the 180bhp as standard
Posted: Mon Dec 19, 2011 2:22 pm |
HDI90 wrote: |
Edward wrote: |
best part of 2k is it worth it? |
i will be interested to see how many people there have actually done all those.
in fact apart from the denmark guy i can't think of any; also see a few guys in frances have put a bigger turbo in but the rpm for the peak torque is just too high up.
fitting a VNT turbo on the pug will never be an easy job because most modern turbo run electronic control wastegate; unless you get one custom build
Posted: Mon Dec 19, 2011 2:59 pm |
Edward wrote: |
520d run GT17 VNT give 150?
seat leon run 757042-5014S give 170
merc B200 run K03 VTG give 140.
but they are all DOHC 16v, unlike the stupid pug which is sohc 8v; i still think this would have at least 10-20% difference in power
Posted: Mon Dec 19, 2011 4:13 pm |
16V shouldn't be necessary on a diesel. 8 valves will flow more than enough at the low revs they run at.
The VW 1.9 engines managed 150bhp as standard.
Posted: Mon Dec 19, 2011 6:08 pm |
Ive just bought a 120d BMW. 180 BHP standard, would push 230 remapped. For me diesels are mainly about torque and not top end, although mine does move quite quickly.
Posted: Mon Dec 19, 2011 6:17 pm |
Steve206 wrote: |
Ive just bought a 120d BMW. 180 BHP standard, would push 230 remapped. For me diesels are mainly about torque and not top end, although mine does move quite quickly. |
turbo technology do advance quite a lot these day; you should have buy the twin turbo 120d
Edward wrote: |
The VW 1.9 engines managed 150bhp as standard. |
could be right, but there is no harm to have more valves and cam
Posted: Tue Dec 20, 2011 9:04 am |
yes 10x to you all for your advice wil go to t3 then
