Latest: airmastertapes
Overall: 17133
Online Now [548]:
Visitors: 547
Today: 91219
Total: 106624810
Forums › The Car › 206 Problems › Ball Joint replacement
ronnie
PostPosted: Thu Dec 29, 2011 4:45 am Up
Has anyone replaced just the bottom Ball Joint on their 206?
We have just replaced the complete A-arm.
and used a superb post by 'Ape' on replacing the A-arm
Both bushes on the old A-arm look fine but we were thinking of replacing the old ball joint and keeping the old A-arm as a spare
On our old Saxo the Ball Joint was easy to replace.....with a couple of sockets and a vice
Is it the same method on the 206?
ronnie
PostPosted: Thu Dec 29, 2011 5:09 am Up
You need to replace the whole arm.
PostPosted: Thu Dec 29, 2011 9:33 am Up
don't think you can.
and that's why you should get a decent wishbone. The ball joint tends to be the first thing to split on the cheap stuff
PostPosted: Thu Dec 29, 2011 9:36 am Up
Genuine Peugeot part's everytime, saves money in the long run Cool
HDI90
PostPosted: Thu Dec 29, 2011 10:06 am Up
I used lemforder on my 206, so far they have been fine
GTI 180
Rob2859
PostPosted: Thu Dec 29, 2011 11:29 am Up
I have seen them separately on ebay but you probably need a press or something to put them in.
