Posted: Tue Jan 10, 2012 11:32 am |
i need to change the steering coloum on my 2001 hdi, how do i go about removing the airbag?
i know i'll need to disconnect the battery but as i'll be leaving it off for a while will it cause any probs with the immobiliser etc?
i've read in the handbook something about the key needing recoding after a battery swap is this so?
also is there any way other than going to peugeot to find the radio code,its working fine atm but probably wont after removing the battery and i dont have the code(just bought the car)
sorry for the simple q's but i'm more used to working on my old 205.....
thanks craig
| | ![](images/spacer.gif) |
Posted: Tue Jan 10, 2012 11:36 am |
Remove battery for 10 mins
Take off steering cowling
Turn steering wheel 90degrees and undo torx screws
Airbag will come out
For radio code - www.paypal.com/cgi-bin...ostedGuest
PM me the VIN
Posted: Tue Jan 10, 2012 12:29 pm |
thanks lee, so i should have no problems with the immobiliser or remote locks etc? i will p/m you tommorow with the vin no.
cheers craig
p.s just a thought, while looking for a 206 i noticed some ads saying it had a reach adjustment for the steering wheel. was this ever an option, maybe on the higher spec cars(mines an lx)
Posted: Tue Jan 10, 2012 1:15 pm |
No problems with immo or keys
Height adjustment on steering is on the left
