Latest: tbafonso
Overall: 17130
Online Now [149]:
Visitors: 149
Today: 5537
Total: 102477819
Forums › The Car › 206 Problems › fuel injector problems
pollypocket
PostPosted: Mon Jan 02, 2012 5:49 pm Up
Hi - I have a 206 1.1 2002 and the engine is running on 2 or 3 cylinders. I have put it into the garage and they said one of the fuel injectors was showing up on the computer as faulty therefore I asked them to change the injector. I picked the car up and it drove fine for 1 mile then the same problem has come back! I returned the car to the garage and they have told me that a different injector has now failed - they think there may be dirt or water in the fuel tank.
This seems a little strange to me - has anyone else experienced a similar problem? Can anyone provide advice on what could be wrong?
Thanks in advance
Sue
I own a 206 Look 1.1 2002
PostPosted: Tue Jan 03, 2012 1:56 am Up
What coilpack and plugs are you running?
gixxerkev
PostPosted: Tue Jan 03, 2012 3:06 am Up
Try filling the fuel tank and add a bottle of injector cleaner. The fuel filter should remove any dirt thats in the fuel. If there is any water in the fuel it'll be at the bottom of the tank as its more dense than petrol and the only way it could get out is if you've been driving around on fumes.
An Ex '03 1.4 GLX driver, German technology all the way now.
PostPosted: Tue Jan 03, 2012 3:11 am Up
Use premium fuel not redex.
DavidPCoates
PostPosted: Tue Jan 03, 2012 2:23 pm Up
Did the garage do a code reader test or just fiddle? The injectors are on 2 seperate circuits, i think 1 and 4 is on one, and 2 and 3 the other.
I recently had 2 injectors go at the same time so it is possible one can affect the other.
Dave
Dave Coates
pollypocket
PostPosted: Thu Jan 05, 2012 3:25 pm Up
Thanks for all your advice folks! Children being children my daughter has been running on fumes frequently!
The first diagnostic check made by the AA said injector 3 was the trouble now it is saying injector 1
I will ask my husband to check the type of ciol pack tomorrow
If water has got into the injectors through running on fumes will they recover or will we need to replace them?
Thanks again
Sue
CrazyDavid
PostPosted: Fri Jan 06, 2012 2:24 pm Up
I know it may sound stupid but which way are you counting 1,2,3,4
I had the same prolem, the code reader said number 3 was down, so from left to right I changed it.
But the missfire did not go away
Then I put the removed injector in numer three, counting right to left
Missfire gone............
206 Gti in China Blue.
PostPosted: Fri Jan 06, 2012 4:20 pm Up
This catches many people out as PSA Peugeot / Citroen like a laugh Laughing
Cylinder order - Number 4 is the TIMING BELT end of the engine.
pollypocket
PostPosted: Sat Jan 07, 2012 7:44 am Up
I Guess that uis French humour! this caught the AA man out - he counted from the left looking for number 3, yet when he took the spark plugs out it was the cylinder next to it that was not working! hey ho all for an interesting life!
pollypocket
PostPosted: Sat Jan 07, 2012 7:45 am Up
unfortunately our problem started with number 3 now it is reporting number 1 injector not working
