Latest: Beduff1977
Overall: 17134
Online Now [479]:
Visitors: 478
Today: 100247
Total: 109270943
Forums › The Car › 206 Problems › Gearbox Failure!!!!!!
andrew206gti
PostPosted: Fri Jan 13, 2012 8:50 am Up
Hi all i hope im posting in the right section, sorry if its not. Here goes. Last friday on my way to work i was driving along nice a sensible and without warning the gearbox blew itself to pieces. i managed to get towed to my local garage and they cant find a 2nd hand replacement gearbox. this is a big problem because they want to get a reconditioned gearbox which is gonna cost me £1100 fitted. Shocked
So im wandering if there is someone on here that can tell me will all 206gti gearboxes fit and work on my 206 gti or is they any differences between them which will cause problems?
hope to hear from someone soon
please help i dont want to scrap it if i can help it
Get in, sit down, shut up \'n\' hold on!!
PostPosted: Fri Jan 13, 2012 9:25 am Up
I have a gearbox, clutch and clutch plate.
andrew206gti
PostPosted: Fri Jan 13, 2012 9:40 am Up
what did they come out of? and what kind of mileage was on it?
PostPosted: Fri Jan 13, 2012 9:41 am Up
206 GTi and did 85k
andrew206gti
PostPosted: Fri Jan 13, 2012 9:53 am Up
what age was the car i have heard that there can be problems fitting different gearboxes as they are all different?
PostPosted: Fri Jan 13, 2012 10:08 am Up
It was a 2001. It's the BE4 box that's fitted to a GTi
PostPosted: Fri Jan 13, 2012 10:25 am Up
Was it the diff that went bang?
andrew206gti
PostPosted: Fri Jan 13, 2012 10:49 am Up
yeah it was the diff that went bang big time. blew a hole straight thro the gearbox casing about 4in across
PostPosted: Fri Jan 13, 2012 10:57 am Up
I suppose you can get another gearbox with any ratios and use your old internals with the new casing and diff...
PostPosted: Fri Jan 13, 2012 11:03 am Up
Would do the lot for £100 including delivery.
andrew206gti
Lee do you know of any codes or numbers on the gearbox? im doing my nut here i have spoke to loads of people today and they are all giving me different codes and numbers and im lost.
PostPosted: Fri Jan 13, 2012 11:06 am Up
Yeah I'll cross reference the codes.
PM me your vin number and I'll show you the results
andrew206gti
PostPosted: Fri Jan 13, 2012 11:08 am Up
Can you do it off my reg number? i havent got my car handy at the mo. how quick do you reckon you could deliver it?
PostPosted: Fri Jan 13, 2012 11:09 am Up
Nah need the vin. Its on the log book and MOT
It would be next day with DHL
andrew206gti
PostPosted: Fri Jan 13, 2012 11:11 am Up
what kind of condition is the box in? i wouldnt want to fit it and it blow up again in a few weeks time lol
