Latest: tbafonso
Overall: 17130
Online Now [73]:
Visitors: 72
Today: 5720
Total: 102080076
Forums › The Car › 206 Problems › Clutch slave cylinder bleed screw
magellan
PostPosted: Sun Jan 15, 2012 10:18 am Up
Hello everybody,
I need to bleed my clutch but I found the bleed screw is in bad shape (rounded and rusted). 9mm spanner slips on it, 8mm is too small, 10mm is too big. I atempted using pliers as well with no success (I get a good grip but the screw seems badly stuck).
I applied a good amount of WD40 with the hope of loosen it more easily but with no luck.
Does anyone have any suggestion before I consider replacing the clutch slave cylinder?
Below is a picture of the bleed scrw so you get a good idea of its condition.
Thank you in advance for you responses.
Michael
ito7
PostPosted: Sun Jan 15, 2012 10:43 am Up
A good amount of heat from an oxy/acetaline torch would do the trick, the thread is still there somewhere! Sam
magellan
PostPosted: Sun Jan 15, 2012 12:27 pm Up
Hi,
Thanksā€¦ I would consider this but I'm not feeling too confident about it: the Haynes manual states the braking fluid might be flamableā€¦ Any risk?
Michael
PostPosted: Sun Jan 15, 2012 12:29 pm Up
As long as you don't use a blow torch, you'll be fine
