Latest: Beduff1977
Overall: 17134
Online Now [166]:
Visitors: 165
Today: 230
Total: 107312679
Forums › The Car › Request a how-to › how to remove rear axle
Forum IndexRequest a how-to
liambez
PostPosted: Mon Mar 07, 2011 1:33 pm Reply with quote Up
hi all anyone have a how to remove rear axle guide around at all. if you do can u pass it on or any links to a how to much appreciated as drivers side trailing arm bearings gone been told its easier and cheaper 2 replace the lot.
pug 206 1.4 project car
cartoonhead
PostPosted: Mon Mar 07, 2011 1:35 pm Reply with quote Up
2 flexi break pipes , 2 handbreak cables , 2 abs wires if you have it and then 4 torx bolts and its off Smile
liambez
PostPosted: Mon Mar 07, 2011 1:37 pm Reply with quote Up
gatherd that much lol but drivers side drum seems to be well and truly bedded on ( think at some point car has been round a lappost as this side of the car has all the problems and has been sprayed again but very poorly.
PostPosted: Mon Mar 07, 2011 1:38 pm Reply with quote Up
Normally by the time you notice the bearing has failed its done much more expensive damage to the rest of the axle Wink
liambez
PostPosted: Mon Mar 07, 2011 1:50 pm Reply with quote Up
i got it as a project car swapped my ps3 for it lol so unsure how long its been like it as i know its been off the road since dec2009 but torsion bar etc is to flexible etc so i was just replacing the lot anyway but cant get the damn rear drum off to get at the handbreak cable and i dont have a angle grinder either. reckon my big hammer will ever crack the casing ?
cartoonhead
PostPosted: Mon Mar 07, 2011 2:05 pm Reply with quote Up
chop it and replace it as they can be bought for just 1 side.
i'd personaly replace both flexis and cables on a axle change even more so if the cars been stood since 2009
liambez
PostPosted: Mon Mar 07, 2011 2:11 pm Reply with quote Up
they have all recently been replaced by previus owner and i can tell there new as still copper rather than greenand cables shiny otherwise i would just cut it lol
Coolspot
PostPosted: Mon Mar 07, 2011 4:51 pm Reply with quote Up
What size tork bolt ore on the axle and do you need a thing special to male sure the axle goes back on straight? i read a 206cc need (positioning calipers)
Is it the same for a normal 1.4 & gti's?
link i got info from below
www.peugeot206cc.co.uk...dg02k3.htm
206 3dr 1.4 GLX modified slightly, Lowered 35mm on full Gmax kit, 17" AEZ xylo alloys 205/45/17, 3.5" Savage back box,
PostPosted: Mon Mar 07, 2011 5:47 pm Reply with quote Up
Was going to ask what cool asked about the bolt, I've angle grinded two axles off now I haven't figuired out what the hell the 4 bolts actually are and what socket is used to remove it it's like the reverse of a torx bolt..
liambez
PostPosted: Mon Mar 07, 2011 5:52 pm Reply with quote Up
i will let u lot know as soon as i find out i know its a e soming the female adaptor for torx heads as soon as i have axle of on wednesday i will update
liambez
PostPosted: Tue Mar 08, 2011 9:42 am Reply with quote Up
As promised but a day early lol the Torx bolts underneither holding the axle on need a E16 Socket there extremely tight but do come undone with a little force. Axle completly off now just got to wait till new one arrives.... noone mentioned how difficult it is to undo the bloody brake pipes tho lol ended up snapping 2 !!!!! ah well more work on the project to be done lol
liambez
PostPosted: Tue Mar 08, 2011 9:43 am Reply with quote Up
scuba
PostPosted: Tue Jan 17, 2012 7:46 pm Reply with quote Up
were are the four bolts located in the boot ?
on it like a car bonnet
JonnyGTI
PostPosted: Tue Jan 17, 2012 8:00 pm Reply with quote Up
the bolts are under the car not in the boot as i have not long done my axle but gonna need to take it off again to do the bushes
Cheers jonny
scuba
PostPosted: Tue Jan 17, 2012 8:07 pm Reply with quote Up
ok thank u i am going to take one off tomorrow and never done it before so just trying to find out the job that awaits for me lol
  Quick Reply
Username:
Message:
Quote the last message
